[P@werPcb] After "Flood", there are such errors, h
vvsvv
Full Member level 1
thermal relief errors report
After "Flood Copper" operation , there are such errors, howto deal with it ??
I have no idea :cry: , and Need your help , Thanks !!!
THERMAL RELIEF ERRORS REPORT -- XC_Final_V2_smallVia2.pcb -- Mon Oct 18 09:54:56 2004
Drilled pads with Nondrilled pads with
less than 50% thermal extensions less than 50% thermal extensions
Report of Thermal Spokes Generator.
On Bottom:
(4615, 1960) # = 1
(883.35, 1363.21) # = 0
(980, 2355) # = 1
(2907.5, 2126.42) # = 0
(1850.2, 1207.15) # = 0
(892.5, 2353.02) # = 0
(2815.24, 1196.79) # = 0
(3342.5, 2276.42) # = 0
(3342.5, 2426.42) # = 0
(660, 1585) # = 1
(2450.71, 3673.91) # = 0
(660, 1765) # = 1
(3424, 3016.23) # = 1
Total Drilled pads: 13 Total Nondrilled pads: 0
Report of Violating Thermal Spokes Remover.
On Bottom:
(2510, 890) # = 1
Total Drilled pads: 1 Total Nondrilled pads: 0
violating thermal spokes remover
it's just a wraning tall you which location thermal spokes less then you setup in SETUP--Preferences--
Thermals field.
pads+less than 50% thermal extensions
May I ignore these errors ?
If I ignore , what will happen ?
what is the difference when
"(2450.71, 3673.91) # = 0 ",
and "(3424, 3016.23) # = 1 " ?
Thanks !!very much!!!
drilled pads with less than 50 thermal extensions
you can ignore it if check connectivity with no error
search location x=2450.71 y=3673.91
you'll see there is no thermal spoke in this position's
pad or via
and location 3424, 3016.23 only have one spoke
ITS JUST A WARNING MESSAGE, WHICH OCCURS IF NO OF SPOKES CONNECTED IS LESS THAN THAT OF YOU SET IN PREFERENCES
