+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 2
    Points: 763, Level: 6
    Join Date
    Apr 2010
    Posts
    46
    Points
    763
    Level
    Buck converter. Timestep too small, error in proteus
    I was trying to design a buck converter as shown in the attached file. When I simulate the converter design in proteus with PWM generated by ATmega32 it is giving a error
    "Timestep Too Small"
    Can you please try to help me with this.
    Attached: Schematic of the converter and the screen shot of the error message.
    Thank you. :)
    The switching frequency used is 1.96kHz
    •   Alt11th June 2012, 10:21
      advertising
  2. #2
    Super Moderator
    Points: 46,735, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,654
    Points
    46,735
    Level
    52
    Re: Buck converter. Timestep too small, error in proteus
    The timestep is on the order of 1.8 x 10 ^ -19. I suppose the unit is seconds?
    This is very slow. I can see it taking weeks to run, and generating a log of results that fills an entire hard disk.
    I don't know how to speed up the time step. Can you find a way to set it faster? Maybe around 10 ^ -6 (a millionth of a second). That's several hundred times your frequency of operation.
    •   Alt11th June 2012, 18:59
      advertising
  3. #3
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Can you post your schematic?
    •   Alt12th June 2012, 07:18
      advertising
  4. #4
    Full Member level 3
    Points: 2,916, Level: 12
    Join Date
    Apr 2006
    Posts
    152
    Points
    2,916
    Level
    12
    Quote Originally Posted by BradtheRad View Post
    Yes make as faster as it can be in my case I have changed it to 50p sec when i had encounterd
