sanks85
Newbie level 6
Hello Guys,
I am using a constant voltage driver (MAX: 45W) to drive RGB Leds (low power) .
Now i need to drive High Power Leds and for which i have to use Constant current driver.
I thought to use LT3956 which could convert constant voltage to constant current output , but the problem is that it has only one channel.
Where as i need RGB channels in the Output.
Any help shall be appreciated
Thank you very much.
