+ Post New Thread
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 20 of 106
  1. #1
    Full Member level 3
    Points: 1,724, Level: 9
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    double volt-ampermeter with pic
    Hey, I'm new on this forum and I want to ask if somebody can help me with hex file for this double volt-ampermeter.
    this is the link: http://electronics-diy.com/product_d...oltmeter%20Kit
    I have searched all the internet but with no result. Have a nice day!
  2. #2
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    Re: double volt-ampermeter with pic
    This is a commercial unit supplied with preprogrammed chip. There may be other projects available with hex file.
  3. #3
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    yes, but i make allready pcb and i put all components toghether on pcb. All i need is a hex file.
  4. #4
    Advanced Member level 3
    Points: 7,560, Level: 20
    wizpic's Avatar
    Join Date
    May 2004
    London
    Posts
    771
    Points
    7,560
    Level
    20
    Quote Originally Posted by Vlad. View Post
    If you do a search here you should find what your after it's been covered in the forum before I wrote some stuff for this meter sometime ago based on that design
    Happy hunting
  5. #5
    Full Member level 5
    Points: 2,738, Level: 12
    Achievements:
    7 years registered
    Li_ereunpisan's Avatar
    Join Date
    Jul 2009
    Bandung, Indonesia
    Posts
    260
    Points
    2,738
    Level
    12
    if you want, I have an example project that i want you
    •   Alt4th June 2012, 13:33
      advertising
  6. #6
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    thanks a lot Li_ereunpisan. is interesting you're project, but if is a single volt ampmeter can a modificy the code source to show me the Voltaje, Intensity and Power in watts?
    •   Alt4th June 2012, 13:43
      advertising
  7. #7
    Junior Member level 3
    Points: 1,180, Level: 7
    Khaderah's Avatar
    Join Date
    Mar 2012
    Europe
    Posts
    29
    Points
    1,180
    Level
    7
    Voltmeter/Ampermeter links
  8. #8
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    thanks all for reply. I think i will make my circuit from the first post and i will try a lot of hex's until i will find one good.
    •   Alt4th June 2012, 15:32
      advertising
  9. #9
    Newbie level 5
    Points: 316, Level: 3
    Join Date
    Jun 2012
    Posts
    9
    Points
    316
    Level
    hey did you find the hex code file .....i do have the same problem.........
  10. #10
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    hey I don't found that hex file. So sad.
  11. #11
    Newbie level 5
    Join Date
    Jun 2012
    Posts
    9
    Points
    316
    Level
    i am also fighting on dat.........did u see this http://www.edaboard.com/thread175584.html
  12. #12
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    I will search later , now I have exams to take. See ya!
  13. #13
    Newbie level 5
    Join Date
    Jun 2012
    Posts
    9
    Points
    316
    Level
    hiiii any update about the hex file
  14. #14
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    Try here, http://elforum.ro/viewtopic.php?f=11&t=68602 i think will be good some hex. I`ve not tested because i don`t have time.
    I am a bad guy, but I have good intentions!
  15. #15
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Check this projects with LCD if you need say:
    LCD 2x16 2xVolt 30V 2xAmp 10A ATMega8
    Click image for larger version.
ID:	77333 Click image for larger version.
Name:	A Circuit.gif
    LCD 4x16 4xVolt 30V 4xAmp 10A ATMega8 TQFP32
  16. #16
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Bandung, Indonesia
    Posts
    260
    Points
    2,738
    Level
    12
    Quote Originally Posted by tpetar View Post
Name:	A Circuit.gif
    hello tpetar...
    where i can see your complete project?
    •   Alt18th July 2012, 14:56
      advertising
  17. #17
    Full Member level 5
    Points: 5,001, Level: 16
    tanveerriaz's Avatar
    Join Date
    May 2001
    Pakistan
    Posts
    287
    Points
    5,001
    Level
    16
  18. #18
    Points: 1,472, Level: 8
    Join Date
    Oct 2007
    Pakistan
    Posts
    29
    Points
    1,472
    Level
    8
    Why do you want .hex file, why not compile it yourself. This is very simple voltmeter, and would need only a few lines of code. the inputs have been scaled down by
    0.0636. so just read in adc, volts and multiply with 1/0.0636 that will give you the input volts. just a 15 min project.
  19. #19
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Quote Originally Posted by Li_ereunpisan View Post
    hello tpetar...
    Uuuuh sorry my friends, I forgot completely to put link.
    Yes that is web address which tanveerriaz give in his post #17
    Only HEX firmware is published.
    On that address you can find many many other nice projects.
  20. #20
    Full Member level 3
    Join Date
    Jun 2012
    Bucharest/Romania
    Posts
    173
    Points
    1,724
    Level
    9
    Quote Originally Posted by ameriq View Post
    hey, if you know can you help to make a soft for a this kind of voltmeter that i post in his post?. Regards.
    I want to show to the LCD: Voltaje, Ampers, Watts(Power) and Rload.
