+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Member level 2
    Points: 1,883, Level: 10
    Join Date
    Jun 2003
    Posts
    51
    Points
    1,883
    Level
    10
    What is a difference between RISC and CISC ?
  2. #2
    Full Member level 6
    Points: 6,614, Level: 19
    Join Date
    Mar 2002
    Australia
    Posts
    386
    Points
    6,614
    Level
    19
    difference between cisc and risc
    Hello zmath,
    Did you try to find something useful with google (keywords: “risc cisc comparison”)? You will get a lot of information about this topic.
    Bye,
    cube007
    1 members found this post helpful.
  3. #3
    Advanced Member level 1
    Points: 6,618, Level: 19
    Join Date
    Dec 2001
    Posts
    467
    Points
    6,618
    Level
    19
    risc and cisc
    RISC : A reduced Instruction Set computer
    CISC : A Complex Instruction Set Computer
    •   Alt14th October 2004, 13:56
      advertising
  4. #4
    Points: 15,991, Level: 30
    Join Date
    Mar 2002
    Posts
    1,309
    Points
    15,991
    Level
    30
    cisc and risc
    I found a great site with a lot of info about CISC and RISC.
    But from the questions asked at EDAboard it doesn't semms that many EDAboard members have heard of of it yet.
    It's a web site called Google: www.google.com
    Please try this link, there's a lot of info about CISC and RISC.
    Maybe we should add this link as an annoucement at the top of the forum.
    They even have info of almost all other topics too.
    If it still doesn't help you, theres something called an encyclopedia.
    Try to look up CISC and RISC in an encyclopedia:
    CISC: http://www.campusprogram.com/referen..._computer.html
    RISC: http://www.campusprogram.com/referen...r/ri/risc.html
    You can even look up other strange microcontroller words such as ARM, AVR, PIC, MIPS, PowerPC, Compiler, Assembler etc. etc.
    3 members found this post helpful.
    •   Alt14th October 2004, 14:40
      advertising
  5. #5
    Full Member level 5
    Points: 3,824, Level: 14
    Join Date
    Sep 2002
    Posts
    311
    Points
    3,824
    Level
    14
    risc cisc
    i think that's a terrific idea!
  6. #6
    Full Member level 1
    Points: 2,198, Level: 10
    Join Date
    Jun 2004
    Posts
    114
    Points
    2,198
    Level
    10
    cisc and risc difference
    RISC has less instructions but more hardware
    CISC has less hardware but more instructions
    •   Alt15th October 2004, 19:38
      advertising
  7. #7
    Full Member level 2
    Points: 2,821, Level: 12
    Join Date
    Mar 2002
    Posts
    145
    Points
    2,821
    Level
    12
    risc&cisc
    Well, simply this is no true.
    As name says (Reduced Instruction Set Computer) RISC has less instructions ussualy with only one clock cycle .
    Whith less instructions you don't need complex instruction decoder, so RISC cores need less transistors (chip area), less power (excelent for mobile units) and higher core speeds than CISCs for same technology.
    First RISC architectures were developed for SPACE programs and GaAs technologies (only 40K transistors per chip). For these technologies RISC is only one solution.
    Main benefit of RISC architecture is high level language programing.
    There is very small defference between programs written in C and programs written in pure assembler.
    RISC is low power, high-speed, compiler and programer friendly high level languages oriented architecture.
    If you need complex instruction (operation) with RISCs you can synthesize this instructions in software with avaliable RISC instructions.
    RISC architectire is not good in all cases especially if your application frequently needs some complex instructions which are not implemented with RISC instruction set.
    With CISC architecture you don't always need all complex instruction for some simple tasks. So in most cases you don't use efficient avaliable chip area and waste chip power.
    For space and mobile products RISC is only one solution for other products you can use CISC or RISC architectures.
  8. #8
    Member level 3
    Points: 1,815, Level: 9
    Join Date
    May 2004
    Posts
    56
    Points
    1,815
    Level
    9
    cisc risc
    hello,
    RISC generally donot implements accumulator, yuo have to work with registers. RISC instructions executes in one clock cycle. For that pipelining concept is used. In RISC number of instructions are less.
  9. #9
    Full Member level 3
    Points: 2,542, Level: 11
    Join Date
    Sep 2004
    Within arm's reach
    Posts
    162
    Points
    2,542
    Level
    11
    risc and cisc architecture
    RISC architecture was invoked by the students of berkeley under the tutelage' of professors Hennessy and Patterson and you can also find a book penned by these two authors.They have explained all the architectural concepts in terms if RISC instructions.The difference between RISC ad CISC is the number of instructions involved which has direct relation with the number of transistors packed inside.for instance even multiplication is written as continuous additions in RISC rather it is a one step process in the case of CISC.This again deals with the delay involved and also with the power dissipation.
    Hope this helps
    Regards
    drdolittle :)
  10. #10
    Newbie level 2
    Points: 1,077, Level: 7
    Join Date
    Dec 2006
    Posts
    Points
    1,077
    Level
    7
    difference between risc cisc
    risc is REDUCED INSTRUCTION SET COMPUTER...
    it has only few fixed instructions like addition substation etc...
    where as cisc have large no of instructions...like multiply divivde etc...
    if we want to multiply in cisc we have to do it using basic equation like adding and shifting...
    main advantage of risc is its reduced complexity....
  11. #11
    Advanced Member level 3
    Points: 8,260, Level: 21
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,260
    Level
    21
    difference between cisc and risc architecture
    Ri sc : data memory and prog memory is separate , instruction set is orthogonal.
    Cise : data memory and prog memory is same , instruction set is not orthogonal.
    Bacisally pc/microprocessor is cise and microcontroller is rise.
  12. #12
    Full Member level 6
    Points: 4,497, Level: 15
    Join Date
    Mar 2006
    Trento, Italy
    Posts
    394
    Points
    4,497
    Level
    15
    risc cisc wikipedia
    basically the in CISC there is common data and address bus is used to fetch the data from code and data memory
    but in the RISC controllers in which the different buses used for the code and data memory
  13. #13
    Points: 10,724, Level: 24
    budhy's Avatar
    Join Date
    Oct 2006
    Indonesia
    Posts
    828
    Points
    10,724
    Level
    24
    difference between risc and cisc architecture
    = von Neuman Architecture, ie Pentium, Motorola 68 series, Renesas M16 series, Renesas H8 series
    = Havard Architecture, ie 8051(CISC), AVR (RISC), PIC (RISC)
    That is not the difference between CISC and RISC!
    •   Alt17th December 2006, 15:42
      advertising
  14. #14
    Newbie level 1
    Points: 490, Level: 4
    Join Date
    Mar 2010
    usa
    Posts
    Points
    490
    Level
    RISC and CISC
    we now know the difference between risc and cisc ,
    but what is the common between them????
  15. #15
    Full Member level 5
    Points: 5,121, Level: 16
    Join Date
    Mar 2006
    Posts
    309
    Points
    5,121
    Level
    16
    Re: RISC and CISC
    dear ameer
    the first common thing is that both are computing machines
    they are made using different hardware architecture
    and both of them had their own qualities
    now the machine developers are trying to develop systems which had the qualities of both RISC and CISC and reduce the limitations.
    ragards
    ml
  16. #16
    Newbie level 2
    Points: 1,021, Level: 7
    xdrone's Avatar
    Join Date
    Jul 2010
    no man's land
    Posts
    Points
    1,021
    Level
    7
    Re: cisc and risc difference
    Quote Originally Posted by Munib View Post
    I know I am couple of years late, but CISC has more hardware to simplify compilation of code. Unlike RISC, takes the complexity from hardware design to software design.
    So to be brief:
    CISC more hardware less software.
    RISC less hardware more software.
    These days, it is hard saying which is what, they are moving into each other.
    So, mmm, some chip might be good in some areas of development, while others might be better in others.
    Overall performance is very very difficult to identify and quantify as code is not constant and will not be similar to other pieces of code.
