+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 5
    Points: 14,833, Level: 29
    Achievements:
    7 years registered
    neazoi's Avatar
    Join Date
    Jan 2008
    Greece
    Posts
    3,019
    Points
    14,833
    Level
    29
    spark gap transmitter multiple series spark gaps
    Hello, I have seen in some old spark gap transmitters multiple spark electrodes in series, that create multiple series sparks. Why they are used in series instead of using just one spark?
    •   Alt1st June 2012, 09:05
      advertising
  2. #2
    Newbie level 5
    Points: 496, Level: 4
    Join Date
    May 2012
    Posts
    8
    Points
    496
    Level
    Re: spark gap transmitter multiple series spark gaps
    To keep the spark in a straight line, so that the total breakdown voltage remains stable/constant.
    •   Alt1st June 2012, 09:51
      advertising
  3. #3
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Which type did you see ? the DC type
    or the AC Rotary Spark gap with RF tuned filter and RF AM modulated key
    I do not know for sure, but this is my opinion based on looking at these photos.
    In either design serial spark gaps make the design more reliable. So that the cleanest contacts at the same gap, would breakdown first, triggering a race to charge-up and dump the remaining shared high voltage charge.
    Either design could use this feature. If you imagine the effect of air capacitors in series each with a limited dielectric breakdown where they short circuit at the breakdown.
    initially even if perfectly equal gaps and capacitance they would split the high voltage equally until the weakest one arcs ( smallest gap). When the 1st dumps, it charges up remaining caps to share the total voltage , which are designed to arc immediately, and thus triggers a rapid successive chain of arcs iafter the 1st.
    The arcs being negative resistance characteristics like SCR's rapidly dumping their charge plates Ic=C*dvt/dt. with high voltage in microseconds..
    Over time spark gap electrodes tended to insulate them with carbon deposits and raise their dielectric breakdown so the gap with the lowest arc voltage always started the chain of breakdown. so having more spark gaps increased the reliability of constant least breakdown voltage. It also increased total capacity of charge Q = C1V+ C2V +...
    The most sensitive or cleanest electrodes and the lowest breakdown voltage, would start the chain reaction in the series string.
    These repeating rotary motor driven impulses could trigger harmonic resonances at a tuned AM band channel to radiate AM RF telegraphy modulated by a telegrapher's "shunted cap" on the low voltage section of the antenna stage.
    So in short ( pun by accident) "multiple spark electrodes in series" the electrodes could be in any physical orientation rotary or linear but always the series. The effects extended the life between maintenance functioning with trigger voltage with the pair with the cleanest contacts which distributed the againg effects while increasing the overal energy of the system with series connected capacitors in effect with almost equal breakdown voltage.
    So that is my rough reverse engineering analysis.
    Fortunately with spark plugs our cars use these days and cleaner burning fuels, we dont think about replacing our spark plugs anymore. I think we often forget they exist.
    Imagine the EMI and Xray emissions with Ozone smell around these machines and the sound effects of rapid fire serial arcs. It must have been magical, Brilliant and slightly dangerous. dah dit dah dah dah dah dah dit dah
    Brilliant.
    I thank you for reading this slightly enlarged explanation. I explains, how I see things hidden from a schematic. It is not brief or best way to teach or explain it.
    But I try to explain the reason why it functions this way and motivation from decades of design experience.
    Tony
    If you agree, vote, if not dont.
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    1 members found this post helpful.
    •   Alt1st June 2012, 12:34
      advertising
  4. #4
    Super Moderator
    Points: 46,819, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,819
    Level
    52
    This looks like something called a Marx generator. There are references to it being used as a transmitter.
