Black gate vs Elna Silmic vs . . ?
thebadtall
Full Member level 6
Hellas
Hello !
I've been designing a low power class A tube amplifier, in order to run 2x12w hi end speakers that Ive recently found.
Everything is fine, except I dont know what capacitors should I use.
Once I had a good expirience with Black Gate capacitors, they clear the sound very well. However, they are expensive.
I heard about Elna Silmic capacitors, wich Ive never used before.
Maybe you could suggest me some cost efficient capacitors ?
Thank you for your time !
