s_hy
hi all,
i have codes about reflective 1d fdtd maxwell equation as below:
the problem is after compiling the wave line i got is not as i expected since i expected gaussian envelope, but the result is as below:
can anyone explain to me why it is happened?
!d fdtd Simulation in free space
subroutine fd1d01(f0,miu,delta,S,E0)
implicit none
real :: f0
real :: miu
real :: delta
real :: S
real :: E0
integer :: iinit
integer :: ilast
integer :: i,j
integer :: t,t0
double precision :: di
integer :: n
double precision :: Ca
double precision :: Da
double precision :: tdelta
double precision :: c
double precision,dimension(100) :: Ez
double precision,dimension(100) :: Hy
real, parameter :: pi = 3.14159265
double precision :: Cb
double precision :: Db
double precision :: lambda
double precision :: alpha
character(len=20) :: filename
f0 = 1.0
miu = 1.0
delta = 1.0
S = 1.0
E0 = 1.0
iinit = 0
ilast = 100
c = 3.e8
lambda = c/f0
alpha = 0.04*lambda
tdelta = 1.0*alpha/(S*c)
!initialization
Ez = 0
Hy = 0
Ca = 1.0
Cb = tdelta/(delta*alpha)
Da = 1.0
Db = tdelta/(miu*alpha)
do n = 0,500
write (filename, "('ez',I3.3,'.dat')") n
open (unit=130,file=filename)
do j = 0,2*ilast
di = 0.5*j
if (Mod(j,2) == 0 ) then !j is even; hence di is whole number
Ez(Int(di-0.5)) = Ca*(Ez(Int(di-0.5)))+Cb*(Hy(Int(di))-Hy(Int(di-1)))
else !j is odd; hence di is 1/2 of whole number
Hy(Int(di)) = Da*(Hy(Int(di)))+Db*(Ez(Int(di+0.5))-Ez(Int(di-0.5)))
end if
write (130,*) Ez(Int(di))
end do
!plane wave source
Ez(50) = E0*sin (2*pi*f0*n*tdelta)
close (unit=130)
end do !n
end SUBROUTINE fd1d01
