+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 3
    Points: 319, Level: 3
    Join Date
    May 2012
    Posts
    31
    Points
    319
    Level
    relationship between transmission and reflection coefficient
    I'm working on a project on calibration,
    i would like to find out whether my results are logical or not.
    are the following statements true?
    S11 = reflection coefficient
    S21 = transmission coefficient
    -20log10 (S11) = return loss
    -20log10 (S21) = insertion loss
    now how is the return loss related to insertion loss?
    or how is the reflection coefficient relates to the transmission coefficient?
    i've read this thread,
    http://www.edaboard.com/thread162644.html
    one member says that
    Transmission coefficient = 1 - ΓL
    but in RF circuit design text book page 85,
    equation 2.86 says that
    To = 1 + Γo
    so...i'm thoroughly confused.
    please help me.
    thanks
    •   Alt22nd May 2012, 02:25
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Re: relationship between transmission and reflection coefficient
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    •   Alt22nd May 2012, 03:42
      advertising
  3. #3
    Full Member level 4
    Points: 2,138, Level: 10
    Join Date
    Oct 2011
    Virginia, USA
    Posts
    220
    Points
    2,138
    Level
    10
    Quote Originally Posted by mtxx View Post
    Those definitions are true. As for the return loss and insertion loss, you need to measure both, you can't necessarily determine one from the other. For a passive device, some of the incident power is reflected, some is transmitted, and some is absorbed (turned to heat). For an active device you have those effects, plus possibly amplification of the signal.
    •   Alt22nd May 2012, 05:03
      advertising
  4. #4
    Join Date
    May 2012
    Posts
    31
    Points
    319
    Level
    Quote Originally Posted by pstuckey View Post
    Really? there's no relationship between these two?
    then i have been mistaken.
    i have measured both S11 and S21,
    and applied some calibration calculations to them.
    giving another S11 and S21, i thought there were some relationship between them,
    that i can use it to verify whether the calibrated S11 and S21 are logical or not.
    was wondering which one is correct.
    To = 1 + Γo
    To = 1 - Γo
    but if there is no relationship between To and Γo, then i will forget about this checking procedure.
    thanks for your answer
  5. #5
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,598
    Level
    100
    Quoting formulas without telling about the described system is pointless.
    If you read the linked Edaboard thread where you took the To = 1 - Γo expression thoroughly, you should have seen the critical comments. It has been clarified that a lossless system would enforce conservation of energy, instead of To + Γo = 1, you get To² + Γo² = 1. So in a short, there are different equations describing different situations.
    In most cases, there is a relation between transmission and reflection coefficient. You can't avoid to analyze the system details to know how exactly.
    1 members found this post helpful.
