+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Banned
    Points: 999, Level: 7
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    RTD PT100 Temperature from Resistance
    Hello!
    Can someone tell me how to calculate RTD PT100 Temperature from its Resistance. I need the equation for calculating temperature from resistance. I've coded for resistance and it is working properly. I need the equation to get the value of temperature from rtd pt100's resistance.
    •   Alt16th May 2012, 12:30
      advertising
  2. #2
    Advanced Member level 5
    Points: 37,620, Level: 47
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
  3. #3
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    •   Alt16th May 2012, 13:23
      advertising
  4. #4
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    Re: RTD PT100 Temperature from Resistance
    The post asks for the inverse calculation. It can be performed based on a polynominal as well. The fit should be calculated based on the intended accuray and temperature range with the necessary order.
    You can use the curve fit feature of a spread sheet calculator like MS Excel to calculate the polynomial coefficients.
  5. #5
    Banned
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    Sorry, but I've checked all those links. The quuation I have is giving the right temperature only upto 100 degree C. Any thing above 100 degree C, I'm getting wrong values.
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    Apparently, you are doing something wrong.
    •   Alt16th May 2012, 13:38
      advertising
  7. #7
    Banned
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    Quote Originally Posted by FvM View Post
    Can you give me the equation?
    ---------- Post added at 20:05 ---------- Previous post was at 20:04 ----------
    Can you give me the equation with polynomial coefficients?
  8. #8
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    1 members found this post helpful.
