+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 6
    Points: 452, Level: 4
    Join Date
    Mar 2012
    Posts
    12
    Points
    452
    Level
    Icarus verilog problem
    I have been using Icarus Verilog along with gtkwave (on various versions of Ubuntu) for a little while now, and it has been great. However, I have recently stumbled onto a problem I am unable to solve.
    This is the makefile I use (simple makefile, that I pretty much found online) :
    VERILOGEX = .v # Verilog file
    # testbench path TESTBENCH is passed from the command line
    TESTBENCHPATH = testbenches/${TESTBENCH}$(VERILOGEX)
    SOURCEPATH = src
    #iverilog CONFIG
    VERILOG_CMD = iverilog
    #VERILOG_FLAGS  =
    # VVP (iverilog runtime engine)
    VVP_CMD = vvp -llogfile -v
    #VVP_FLAGS =
    #Simulation Vars
    SIMDIR = simulation
    DUMPTYPE = vcd
    #Viewer
    WAVEFORM_VIEWER = gtkwave # Waveform viewer executable
    all: compile run view
    file_check:
    ifeq ($(strip $(FILES)),)
    	@echo "FILES not set. Use FILES=value to set it. Put mutltiple files in quotes"
    	@exit 2
    endif
    testbench_check:
    ifeq ($(strip $(TESTBENCH)),)
    	@echo "TESTBENCH not set. Use TESTBENCH=value to set it."
    	@exit 2
    endif
    check: file_check
    	$(VERILOG_CMD) -t null $(FILES)
    # Setup up project directory
    new :
    	echo "Setting up project ${PROJECT}"
    	mkdir src testbench simulation
    compile : testbench_check
    	mkdir -p simulation
    	$(VERILOG_CMD) -o  $(SIMDIR)/$(TESTBENCH) $(TESTBENCHPATH) $(SOURCEPATH)/*
    run : testbench_check
    	$(VVP_CMD) $(SIMDIR)/$(TESTBENCH) -$(DUMPTYPE) $(VVP_FLAGS)
    	mv dump.$(DUMPTYPE) $(SIMDIR)/$(TESTBENCH).$(DUMPTYPE)
    view : testbench_check
    	$(WAVEFORM_VIEWER)  $(SIMDIR)/$(TESTBENCH).$(DUMPTYPE)
    clean : testbench_check
    	rm $(SIMDIR)/$(TESTBENCH)*
    The basic use is:
    make all TESTBENCH=testbench.v
    I have simulated many minor design with this setup, without any problems. However when simulating my last design, which is a bit larger (containing around 20 modules) the simulation gets a bit problematic.
    Initially, the simulation finished without any problems. But as the testbench passes a certain amount of clock cycles, the simulation never finishes. No error message appears, and it does not crash, it just never finishes. The last message to be printed is this:
    VCD info: dumpfile dump.vcd opened for output.
    I tried simulating the exact same files in Active HDL (student edition, Windows), and it worked fine. It didn't take more than a second or two either, so the runtime is not the problem it seems.
    I have tried letting iVerilog run for quite some time too without any luck. I could of course just switch to Active HDL and Windows, but that would be a last resort, as I already have a good setup going in Ubuntu with IVerilog and gtkwave.
    I tried using diiferent output formats, such as lx2 etc. as well but it didn't help.
    Anybody got any thoughts?
    Any help is greatly appreciated!
    •   Alt15th May 2012, 20:14
      advertising
  2. #2
    Advanced Member level 5
    Points: 11,741, Level: 25
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    Re: Icarus verilog problem
    Quote Originally Posted by ned_zeppelin View Post
    i think this peculiar problem can be answered by stephen williams(icarus write).
    you can post your problem in:
    https://sourceforge.net/mail/?group_id=149850
    you may get a solution.
