+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 1
    Points: 1,643, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    New Delhi
    Posts
    Points
    1,643
    Level
    9
    Transceiver Design as per DVB-T Standard
    I need to design a Transceiver as per DVB-T Standard where the o/p power at the transmitter has to be 500mW in the band 2.0-2.4GHz.
    Can you please suggest which company provide the processor/FPGA for (Encoder, Compressor, Modulator, DAC) in single chip plus up-converter.
    Also I am not able to figure out the transistor for amplifier within my band with 500mW power output.
    •   Alt10th May 2012, 07:56
      advertising
  2. #2
    Advanced Member level 2
    Points: 6,074, Level: 18
    Join Date
    Jan 2007
    Sweden
    Posts
    603
    Points
    6,074
    Level
    18
    Re: Transceiver Design as per DVB-T Standard
    DVB-t is not is allowed to transmit in 2.4 GHz and it does not exist any single chip transceiver solutions for DVB.
    This is the most flexible, almost single chip, RX receiver I know about.
    DIB7000 - DIB7790 is a very common single chip receiver that can be found in USB dongles and similar simpler DVB-t receivers.
    DVB-t TX is a very complex thing that requires I/Q modulation with low phase error. No single chip solution for streamer/coding/modulator exist as far as I know.
    This is a simple modulator.
    Output from a Teamcast box comes two modulated signals, I & Q, with a carrier decided by which type of data-stream you have selected, so you need to add a I/Q capable up-converter of your choice before any PA. As PA must be very phase linear do I not think a single transistor solution is the best type of PA.
    The Teamcast box must be feed with something able to deliver a digital TS at correct bitrate. Most simple is to use a simple data buffer that can pick data from a TS-file.
    Another possibility is to check at www.dvb.org as I have heard planes about a standard for micro DVB-s2/h repeaters, in size of a shoebox. Not a single chip solution but at least a single box. If you must use 2.4 GHz do I think it exist a Chinese digital TV standard in 2.6-2.7 GHz or something like that and very similar protocol as DVB-h. It is not so fare away in frequency, but doubt they have any single chip transceivers.
  3. #3
    Newbie level 3
    Points: 55, Level: 1
    Join Date
    Sep 2012
    Posts
    Points
    55
    Level
    I wonder if you are still looking for such a solution.
    The first DVB-T transmitter ASIC IC is now available. The code name is IT9500.
    Basically, DVB-T is transmitted at RF below 1GH as you know.
    However, you may change the local oscillator of the up converter(mixer) to 2.4G, so it can Tx at 2.4GHz.
    With external power amplifier(PA) , it's easy to to boost the RF signal to 500mW (it's about 27dbm).
    The only problem is that how can you receive 2.4 G DVB-T signal?
    •   Alt13th September 2012, 14:26
      advertising
  4. #4
    Join Date
    Jan 2007
    Sweden
    Posts
    603
    Points
    6,074
    Level
    18
    Link to technical info about IT9500?
    1 members found this post helpful.
  5. #5
    Newbie level 3
    Join Date
    Sep 2012
    Posts
    Points
    55
    Level
    Quote Originally Posted by E Kafeman View Post
    IT9500 has not been released publicly yet. It's going to be announced soon (around Q4, 2012).
    There are some early product designs with IT9500 , refer to http://www.hides.com.tw/product_eng.html.
  6. #6
    Join Date
    Jan 2007
    Sweden
    Posts
    603
    Points
    6,074
    Level
    18
    Impressed that it is possible to make a complete DVB-T transiver fit in a USB dongle.
    Thanks for information.
    •   Alt14th September 2012, 04:56
      advertising
  7. #7
    Points: 1,831, Level: 9
    Join Date
    Dec 2005
    Posts
    7
    Points
    1,831
    Level
    9
    Hi
    I HAVE DVB-Ttx MODULE,can custom made。if anyone have interesting,please email :szfpga@gmail.com
