+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Newbie level 3
    Points: 1,129, Level: 7
    Join Date
    Mar 2009
    Posts
    Points
    1,129
    Level
    7
    Ac Voltage regulator using Triac
    I need to make ac voltage regulator from 220 ac to 110 ac for load 10 A , 1000 Watt
    it's my first time to use a triac and i need help in that (circuits and ratings)
  2. #2
    Advanced Member level 5
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Re: Ac Voltage regulator using Triac
    Dear elleader
    Hi
    It is simple , but what is your problem , exactly ? in feed back section ? in triac driver ?
    Best Luck
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
  3. #3
    Newbie level 3
    Join Date
    Mar 2009
    Posts
    Points
    1,129
    Level
    7
    every thing about this object
    if i need to use micro controller or not
    and the suitable components for the load
    Thnx in advance goldsmith
  4. #4
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    I think you can use another components , e.g two mosfet , it will be more suitable , because you can turn off your mosfets at your desired time simply , but about triacs : if you turn them on , if you want turn them off with command signal , it will be a bit difficult .
    So , at first , tell , me , please , that is it important to you , to use triac , exactly ? why not two mosfet ?
    Best Wishes
    Goldsmith
  5. #5
    Newbie level 3
    Join Date
    Mar 2009
    Posts
    Points
    1,129
    Level
    7
    I need only to make this
    if u know any good way tell me
    and explain it
  6. #6
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Well , see below , please :
    Click image for larger version.
Name:	AC voltage.JPG
    If you can't understand it's behavior , i can describe it !
    Good luck
    Goldsmith
    1 members found this post helpful.
  7. #7
    Newbie level 3
    Join Date
    Mar 2009
    Posts
    Points
    1,129
    Level
    7
    Thnx goldsmith
  8. #8
    Junior Member level 1
    Points: 352, Level: 4
    Join Date
    Oct 2012
    Posts
    19
    Points
    352
    Level
    @Goldsmith:
    Can u give me brief detail about that component?
    If I want to use TRIAC to regulate the voltage.
  9. #9
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    @Goldsmith:
    Hi Omshankar
    About what component ? triac ? or mosfet ?
    Of course you can use triac to regulate average voltage but , it needs more complicated circuits instead of Mosfets !
    Best Wishes
    Goldsmith
  10. #10
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Quote Originally Posted by omshankar View Post
    @Goldsmith:
    When using triac, the output will be regulated either by means of phase angle control or pulse skipping modulation. Thus the output is regulated by wave shape distortion or modification. You do not end up with the same wave shape as the input. Also, the peak voltage is 220 * √2 and not 110 *√2.
    So, using triac may be okay for certain loads. But it won't be okay for all loads. So, keep in mind the drawbacks I have mentioned. It is better to use MOSFETs and SPWM to regulate the voltage and not distort output wave shape.
    Hope this helps.
    Tahmid.
    The blissful feeling of helping others is a unique reward that cannot be gotten from anything else.
  11. #11
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    For resistive loads like iron, bulb heater etc.
    Replace TIC226 with high current triac, like BTA16 and 10A fuse instead of 2A.
    http://homemadecircuitsandschematics...ormerless.html
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
  12. #12
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hi Tahmid
    Who told that this arrangement don't have THD ? it has of course ! but it's value is lower instead of classical method .
    Best Wishes
    Goldsmith
  13. #13
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Quote Originally Posted by goldsmith View Post
    Hi Tahmid
    Best Wishes
    Goldsmith
    Perhaps you did not understand what I meant.
    When using pulse skipping or phase angle control, the output wave is not a proper continuous sine wave. For pulse skipping, a lot of cycles are (as the name suggests) skipped. For phase angle control, part of the cycle is "cut", so what you have at the end is not a continuous proper sine wave.
    However, in MOSFET-based PWM-based switching converter, at the output you will get a proper continuous sine wave, but with a certain level of impurity or distortion. However, you have a complete proper sine wave. The basic shape of the wave is not disrupted or distorted as you get a proper continuous sine wave.
    A diagram would better illustrate the associated problem.
    Consider the 3 diagrams below for phase angle control at 3 different angles. While average value is reduced, the peak voltage isn't and the wave is not a continuous sine wave.
    I hope I could make myself clear.
    Hope this helps.
    Tahmid.
  14. #14
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Tahmid , your statement is a bit confusing because at post #10 you've told that
    And now you're telling
    I know principles of controllers with triacs and mosfets as well . and i understand what is your aim . you can use proper words to avoid this confusions . isn't it ?
    Respectfully
    Goldsmith
  15. #15
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Perhaps you found my statements ambiguous. But I thought I was clear enough.
    I meant distortion of the sinusoidal shape of the wave as "disruption" as it's used in plain English, not in a technical context as in harmonic distortion.
    Hope I could make it clearer.
  16. #16
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    What is your definition by distortion ? we have three kind of distortion :
    1-Phase distortion
    2-frequency distortion
    3- amplitude distortion
    Are you familiar with fourier series ? if yes , try to mention spectrum of such signal . what you'll see ? or give it to an spectrum analyzer ? ( do you have spectrum analyzer ?) if yes see it . then you'll understand what i'm trying to refer .
    Regards
    Goldsmith
  17. #17
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    I was talking about the plain English word distortion meaning deformation or twisting out of shape, not in a technical context.
  18. #18
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    My friend , why we are here ? to talk about technical issues . not anything else .
  19. #19
    Newbie level 6
    Points: 1,884, Level: 10
    Join Date
    May 2004
    Riyadh, Saudi Arab
    Posts
    11
    Points
    1,884
    Level
    10
    I want to trigger TRIAC from 175 degree to 179 degree range of AC220 V cycle. could a simple RC trigger circuit do it? like the one used in ceiling fan speed regulator.
  20. #20
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hi seaspac
    If you need that precision , one or two RC networks for trigger are not trust able to be so precise . i think you'll need a digital trigger pulse generator like a micro controller and then taking feedback and also using a zero cross detector .
    Best Wishes
    Goldsmith
