+ Post New Thread
Results 1 to 18 of 18
  1. #1
    Points: 6,654, Level: 19
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Do you know how to use USART on STM32?
    Helo friends,
    I've been doing USART on STM32 and got this at putty:
    Click image for larger version.
    Actually I want to display :
    printf("*  Thank you for using the board");
    Do you have idea why ?
    Thanks
  2. #2
    Full Member level 6
    Points: 2,878, Level: 12
    Join Date
    Nov 2009
    Sao Paulo, Brazil
    Posts
    390
    Points
    2,878
    Level
    12
    Re: Do you know how to use USART on STM32?
    I have used STM32 on several projects but never used the printf function. I have made my own communication functions. You should try using the USART on a RAW mode for now, just sending a few chars to check the communication. The STM32 stdperiph Lib might help you on that.
    Cya
  3. #3
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Quote Originally Posted by Sink0 View Post
    Cya
    Do you have example on it ?
  4. #4
    Full Member level 4
    Points: 1,381, Level: 8
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    •   Alt18th April 2012, 00:29
      advertising
  5. #5
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Thanks for the info mate...
    ---------- Post added at 00:42 ---------- Previous post was at 00:39 ----------
    Do I need max232 converter for it ? I think it's because I don't use Max232 ?
  6. #6
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    you are using a 3.3V logic micro... you need a max3232, or a 3.3V logic ftdi, you can also make an auxiliary circuit with transistors to handle rs232 levels... but I would use one ftdi
    ______
    note... if you are using an development board, probably you already have built on board ftdi or max3232
  7. #7
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Quote Originally Posted by mgate View Post
    ______
    do you have the auxilary circuit with transistor to handle rs232 level ?
    ---------- Post added at 01:48 ---------- Previous post was at 01:34 ----------
    there's PL2303HX onboard, but window7 can not use virtual COM Port from ST....do you have ideas ?
    or I will create my own converter and connect to PA9 and PA10 with MAX232
    ---------- Post added at 01:51 ---------- Previous post was at 01:48 ----------
    This device cannot start. (Code 10)
    •   Alt18th April 2012, 01:51
      advertising
  8. #8
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    people with same problem found the solution...
    http://social.technet.microsoft.com/...b-1352515a4fe6
    basically you have a Chinese fake
    Warning Notice:
    It is recently confirmed that counterfeit (fake) PL-2303HX USB to Serial Controller ICs using Prolific's trademark logo and device drivers were being sold in the China market. Counterfeit IC products show exactly the same outside chip markings but generally are of poor quality and causes driver compatibility issues (Error Code 10). We issue this warning to all our customers and consumers to avoid confusion and false purchase.
    Please be warned that selling counterfeit products are illegal and punishable by civil and criminal courts according to the trademark, copyright, and intellectual properties laws and regulations. Prolific will take proper and severe actions to cease and confiscate these counterfeit products. Prolific also prohibits the distribution of any PL-2303 drivers (including download links) without written permission from Prolific.
    Prolific advices end-users to only purchase branded cable products with company name contact information for service and support in case you suspect a counterfeit chip inside. You may also contact Prolific to provide the vendor information.
    So you need to get old version drivers to solve it...
    ---------- Post added at 03:06 ---------- Previous post was at 02:11 ----------
    You will want to check this article:
    •   Alt18th April 2012, 03:06
      advertising
  9. #9
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    It works ok with my module ( just created ) MAX232 chip is being used for the module..
    thanks for helping :)
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    I tested it on putty 115200 baud
  11. #11
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    have you tested with the PL2303HX ?
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    I'm using Profilic USB to Serial Converter then connect into my handmade MAX232 converter, then connect to PA9 and PA10...so far no problem...
  13. #13
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    Sorry, I was asking if you had try to use directly the onboard PL2303HX as you said
    •   Alt18th April 2012, 04:03
      advertising
  14. #14
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    For that one , I can not make the Virtual COM Port from STM to run in window7 64bits, may be there's a bug...
  15. #15
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    I posted the solution for that problem above ;)
    just follow the link and install the mentioned drivers as vista compatible under admin rights
  16. #16
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    I installed that driver already and my USB to serial converter is working now, but there is another chip on board that has a different preference with this USB converter, your answer is right for USB to serial converter but it's different with the 2303 onboard, I must use driver from ST, they call it ST Virtual COM port, and it's not working, actually it's for downloading my code...but now I'm using JLink for replacing it, doesn't matter, work the same..
    ---------- Post added at 04:27 ---------- Previous post was at 04:26 ----------
    Have you done your own customized uCGUI ?
    Where's the starting point for it ?
    Thanks
  17. #17
    Full Member level 4
    mgate's Avatar
    Join Date
    Apr 2012
    Portugal
    Posts
    197
    Points
    1,381
    Level
    8
    didn't know about that st issue
    Well, I've just added a few buttons... It is similar to windows API programing... anyway, I never managed to get the full free uCCOS, so I prefer to use freeRTOS
  18. #18
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    USB to serial converter and the small MAX232 module that I had created just now
Name:	RS232 and handmade module.jpg
