Finding positive flop to negative flop timing reports
kpsr
Member level 1
Hi folks,
I am doing synthesis (RTL compiler) it generate the different timing reports such as
input to output
input to seq
seq to seq
seq to output
But how to find the timing reports between positive flop to negative flop.
what are the commands are used for finding the timing between positive flop and negative flop
please give the solution as early as possible.
Thanks in advance
kpsr.
The timing between positive flop and negative flop is also categorized as seq to seq as well. Here the difference is, the data has only half clock period to meet setup instead of full clock period. But the advantage is gain of half cycle margin on hold check.
You can use "report_timing -from -to " to get specific path timing information.
Reactions: kpsr
    kpsr
in primetime when yu do report_timing you can see the report like this
Startpoint: ffa (rising edge-triggered flip-flop clocked by CLK)
Endpoint: ffd (rising edge-triggered flip-flop clocked by CLK)
now in the above case startpoint and end point is of both rising edge flipflop... and its because in the report_timing you have provided such paths with the help of -to and -from
so using these 2 switch you can change the reports.. apart of this there are few more switched like -rise_from -fall_from -rise_to and -fall_to .. use proper combination and validate it with the help of reporting header.
Reactions: kpsr
    kpsr
There are two types.
Positive and Negative edge triggered FF.
If Clock is driven by Positive edge triggered FF . Its Positive edge timing report.
If inverted clock driven by Positive edge triggered FF . Its negative edge timing report.
If Clock is driven by Negative edge triggered FF . Its negative edge timing report.
If inverted clock driven by negative edge triggered FF . Its positive edge timing report.
Now you got totally 4 combinations to analyze the reports.
if its single clock design, you can easily get this by writing simple perl script.
If its multi clock design, by using attributes, you can write simple script in PT/Dc.
