LDV5.1 error: ncsim: error while loading shared libraries
gold_kiss
Full Member level 4
LDV5.1 problem
Hi all,
i got the following error on running RUN_NC script generated by ncprep...in the ncsim section.
ncsim: error while loading shared libraries: libudm.so: cannot open shared object file: No such file or directory
Please help me ..what is cause of this error.
thanks,
Gold_kiss
LDV5.1 problem
i too faced this same problem,
you have to give the following setting in your .cshrc file in csh shell
"setenv LD_LIBRARY_PATH $HOME/ncv/tools/lib"
=>$HOME/ncv/tools/lib --> locates the shared libraries: libudm.so:
set the above mentioned setting and enjoy.....
Re: LDV5.1 problem
Hi Arvind,
I tried this one but still it doesnt work.
any other work around?
Thanks
Gold_kiss
Re: LDV5.1 problem
Specify what kind of Linux version are you using, LDV5.1 work only with the Linux distribution Cadence stated in their Website
LDV5.1 problem
Do you make a new link form 'tools.lnx86' to 'tools'?
