+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Full Member level 6
    Points: 1,956, Level: 10
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    How to determine with DMM which one is the start winding & which one is run winding
    How to determine with DMM which one is the start winding & which one is run winding in a single phase AC motor ?
    Where to connect the capacitor ?
  2. #2
    Full Member level 5
    Points: 1,591, Level: 9
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    Re: How to determine with DMM which one is the start winding & which one is run windi
    As far as i know ..... run windings have relatively least resistance as compared to start windings ....
    http://images.elektroda.net/38_1334401059.gif
    •   Alt14th April 2012, 11:58
      advertising
  3. #3
    Full Member level 3
    Points: 1,858, Level: 10
    Join Date
    Jun 2011
    Posts
    159
    Points
    1,858
    Level
    10
    The start winding has a high resistance compared to the run winding
    Its best to measure the ohms with a analog multimeter
    The capacitor will be connected in series with the start winding
  4. #4
    Full Member level 6
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    What is centrifugal switch ? why its used here ?
    Where to connect / apply phase & where to neutral ?
  5. #5
    Advanced Member level 5
    Points: 11,730, Level: 25
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    a centrifugal switch is operated by rotational force.
    it will be in closed position at start of rotation and until a set speed is reached.
    beyond which , it will open.
    the centrifugal switch is connected to aux wndg circuit.
    So that , aux wndg will be connected at satart. when motor is reaching the full speed it will be cut from supply by centrifugal switch.
    you can refer the diagram , attached in the earlier message.
  6. #6
    Full Member level 6
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    if we don't use the centrifugal switch then what might happen ?
    where must be the neutral & phase connected ?
    •   Alt14th April 2012, 23:33
      advertising
  7. #7
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    Quote Originally Posted by munzir View Post
    then it will be classified as 'capacitor run' motor type.
    •   Alt14th April 2012, 23:39
      advertising
  8. #8
    Full Member level 6
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    & with centrifugal switch what type of motor it would be ?
  9. #9
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    capacitor -start motor type.
  10. #10
    Full Member level 6
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    difference between capacitor start motor & capacitor run motor ?
    which one is used in fans ?
  11. #11
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    capacitor run.
  12. #12
    Full Member level 5
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    what's the difference between these two ?
    can we interchange capacitor run motor with capacitor start motor ?
  13. #13
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    if those two satisfies the starting torque , then yes.
  14. #14
    Full Member level 6
    Join Date
    Oct 2011
    Pak
    Posts
    365
    Points
    1,956
    Level
    10
    how can we compare or can check whether they're satisfying the starting torque ?
  15. #15
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,797
    Points
    11,730
    Level
    25
    first the HPs and rpms should satisfy. from the specification of the two motors , starting torque is to be satisfied.
    •   Alt19th April 2012, 18:29
      advertising
  16. #16
    Full Member level 5
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    how to satisfy the starting torque ?
