phaedrus
Member level 4
Hi ,
I need some help with calculations for modified sine wave inverter (square wave with deadband).
I have to power a variable frequency drive system / induction motor which is rated for 7.5HP ( 5500W ) @ 470V ; measured with multimeter.This is to supply the drive when the 415V phase to phase mains voltage is lost.
It will run for a maximum of 2 minutes.
The possibilities are for using
A) 12V (7.6AHr battery) x 4 = 48V
B) 12V (7.6AHr battery) x 6 = 72V
Is there any way to get a good estimate of the current requirement from the battery for both the possibilities ?
