+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 5
    Points: 463, Level: 4
    electricMac's Avatar
    Join Date
    Apr 2012
    United Kingdom
    Posts
    10
    Points
    463
    Level
    HFSS lamda/2 dipole antenna
    Hello people!
    I'm trying to create a λ/2 dipole antenna at 402MHz, but i have some questions.
    Is there a rule to follow on setting : 1)the dipole radius?
    2)the source rectangle?
    3) the dimensions of the cylinder (of air) on which i will assign radiation?
    P.S. I'm using HFSS v11!
    Thanks in advance
    •   Alt4th April 2012, 02:56
      advertising
  2. #2
    Full Member level 4
    Points: 2,819, Level: 12
    Join Date
    Oct 2006
    Posts
    234
    Points
    2,819
    Level
    12
    Re: HFSS lamda/2 dipole antenna
    dipole radius = lambda/200
    gap_source = lambda * 0.0125
    res_length = 0.475 * lambda
    dipole length = res_length/2 - (gap_source/2)
    2 members found this post helpful.
    •   Alt4th April 2012, 18:35
      advertising
  3. #3
    Full Member level 4
    Join Date
    Oct 2006
    Posts
    234
    Points
    2,819
    Level
    12
    one more:
    airbox = lambda/4 (minimum)
    •   Alt5th April 2012, 06:44
      advertising
  4. #4
    Full Member level 6
    Points: 2,844, Level: 12
    Join Date
    Nov 2011
    Posts
    379
    Points
    2,844
    Level
    12
    Quote Originally Posted by kae_jolie View Post
    one more:
    Note if you designing an antenna for 100 MHz, but are intending simulating the antenna from 80 MHz to 123 MHz, then you must use the lowest frequency (i.e. 80 MHz) in the calculation.
    Another thing to watch is that for accurate simulation of the far-field, you must ensure that the maximum size of the tetrahedrals on the boundary is less than lambda_max/6, where lambda_max is the maximum frequency you simulate over. So in this case, you would need to find the wavelength at 123 MHz, and that value. I'm no expert on this, but I believe that this is more critical if you are interested in the far field radiation pattern, and is less important if you are only interested in measuring parameters at the port, such as S11.
    Dave
    1 members found this post helpful.
