bhan1992
Member level 1
hi all,
A hard disk uses a connector with 4 pins (+12V GND GND +5V)
I tried to connect a AC/DC 12V 250 mA adapter to power the hard disk. I connect the 12V to the 12V pin of the hard disk and uses a 7805 to convert the 12V to 5V and connect to the 5V pin on the hard disk, it won't work.
Need your help a bit here. Could it be I don't have enough amp to power the hard disk? can i connect that 2 GND pin together?
Thank you for your reply in advance.
