+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 3
    Points: 144, Level: 1
    Join Date
    Mar 2012
    Posts
    Points
    144
    Level
    Digital Tachometer VHDL
    I have this project where I have to design a tachometer using VHDL. The thing is I m pretty new to the field of electronic projects and I m very new to VHDL.
    The project asks me to count the Rotations/per Minute from a motor.
    It has to be in the range 19-98 RPM, the measurement time is 1.1s, and the display resolution is 0.1 .
    The good part is that I dont have to create a system to get this rotations, they are given to me thru a generator. I just have to count the pulses and display the result.
    http://imageshack.us/photo/my-images/546/blockvk.jpg
    So, I tought I'll use an AND gate with the signal from the general as one input and the clock divided so I'll obtain the period of 1.1s .
    http://imageshack.us/photo/my-images/839/clockbg.jpg/
    What I have to do next is when i press a button it will count the pulses for 1.1s and then display the result. [During counting the display will be OFF].
    Sorry for the long post but the first problem resumes to this. How do i design a clock divider so I can get a period of 1.1s.
    I have a basic clock divider code where i count the rising edges and then i change the state of clock. But how many edges i have to count?
    ENTITY CLKDIV IS
    PORT(
    CLK: IN STD_LOGIC;
    CLKOUT: OUT STD_LOGIC
    END CLKDIV;
    ARCHITECTURE DIV OF CLKDIV IS
    BEGIN
    PROCESS (CLK)
    VARIABLE COUNT: INTEGER RANGE 0 TO ????  :=0;
    VARIABLE STATE: STD_LOGIC := '1';
    BEGIN
    IF(RISING_EDGE (CLK)) THEN
     IF(COUNT=  )THEN
    COUNT:=0;
    STATE:= '1';
    ELSE
    COUNT := COUNT+1;
    END IF;
     IF(COUNT=)
    STATE:= NOT STATE;
    END IF;
    END IF;
    CLKOUT <= STATE;
    END PROCESS;
    END DIV;
    •   Alt25th March 2012, 09:33
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,870, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,564
    Points
    35,870
    Level
    46
    Re: Digital Tachometer VHDL
    dont do clock dividers with logic. you should make clock enables instead. Logic generated clocks are prone to timing problems.
