+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
  1. #1
    Newbie level 1
    Points: 143, Level: 1
    Join Date
    Mar 2012
    Posts
    Points
    143
    Level
    sine wave with different frequency using FPGA
    hello,
    am working on a project waveform generation using fpga , i did sine wave with 1k freq(verilog, vhdl) but now i required sine wave with freq. upto 400khz plz gimmi some tips.
  2. #2
    Member level 1
    Points: 671, Level: 5
    Join Date
    Feb 2012
    Posts
    32
    Points
    671
    Level
    Re: sine wave with different frequency using FPGA
    Hi!
    U want a sine wave generator, with switchable (adjustable) frequency? If this is the case, I'm doing similar project right now.
    What technic do u used for sine gen? Can u post your code?
    In most sine generators, they using a "base" frequency, so u will need an adjustable clock divider to supply adjustable base frequency to sine gen.
  3. #3
    Junior Member level 1
    Points: 801, Level: 6
    Join Date
    Aug 2011
    New Jersey, USA
    Posts
    19
    Points
    801
    Level
    I would create a DDS process (Direct Digital Synthesis). There is also a DDS Compiler IP Core, if you have that. But it can be hand-coded with ease. Read:
    http://en.wikipedia.org/wiki/Direct_digital_synthesizer
    http://www.analog.com/library/analog...38-08/dds.html
    http://www.analog.com/static/importe...rev12-2-99.pdf
    Basically an accumulator input into a ROM to map phase to amplitude.
    - Ryan
    1 members found this post helpful.
    •   Alt20th March 2012, 19:53
      advertising
  4. #4
    Member level 1
    Join Date
    Feb 2012
    Posts
    32
    Points
    671
    Level
    I'm using an iteration based code, it's iterates trough the values of 1/4 of a sine wave. http://www.doulos.com/knowhow/vhdl_d...ave_generator/ - just in my case, I rewriteing the code for 0 to 3.3V output.
  5. #5
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    It's a very "basic", fixed frequency generator. If you want to do anything with variable frequency, you should really learn about the DDS concept mentioned by Ryan. You'll also find various previous edaboard threads related to the topic.
  6. #6
    Member level 3
    Points: 504, Level: 4
    Join Date
    Dec 2011
    Posts
    62
    Points
    504
    Level
    If you use Xilinx device, I would start from here: http://www.xilinx.com/products/intel...S_Compiler.htm . This IP is available in Xilinx Core Generator tool.
    Quote Originally Posted by Raviraj Sarje View Post
    hello,
    Cheers,
    Jim
  7. #7
    Member level 3
    Points: 2,104, Level: 10
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    I am generating 25MHz Sine wave using DDS core. Simulation is working perfectly but hardware is not working. I am implementing simple DDS core. Can you please tell me what can be the possible reason?
    •   Alt28th March 2012, 21:22
      advertising
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    I fear, that's far from a clear problem description.
  9. #9
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    My code for the core is
    entity dds_test is
    Port (
    clk : in STD_LOGIC;
    rdy : out STD_LOGIC;
    sine : out STD_LOGIC_VECTOR(5 downto 0));
    end dds_test;
    architecture Behavioral of dds_test is
    component dds
    port (
    clk: IN std_logic;
    rdy: OUT std_logic;
    sine: OUT std_logic_VECTOR(5 downto 0));
    end component;
    begin
    Sine_wave : dds
    port map (
    clk => clk,
    rdy => rdy,
    sine => sine);
    end Behavioral;
    and simulation results are
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    O.K., the simulation looks plausible. So what's happening with the hardware design?
    •   Alt28th March 2012, 22:35
      advertising
  11. #11
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    i am assigning that 'rdy' pin to a led but led is not glowing on fpga.
  12. #12
    Advanced Member level 5
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,434
    Level
    45
    the the LED active low?
  13. #13
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    no it is active high
  14. #14
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    If I understand right, your DDS design has all fixed parameters and no programming interface, so RDY is actually useless. But is should work if present. Reasons that I can imagine:
    - DDS core is hold in reset
    - IO pins not assigned correctly
    - intended configuration not loaded
    There are means to check each point separately.
  15. #15
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    yes, you are right all parameters are fixed. And what do you mean by DDS core is in Reset state? how i can check it?
  16. #16
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    If you omitted SCLR, the DDS core can be only hold in reset by the global FPGA power-on reset. Do you check, if the intended FPGA design is loaded at all? Is it clocked correctly? Are any other parts beside the DDS core working? Output pins driving out?
    •   Alt28th March 2012, 23:12
      advertising
  17. #17
    Join Date
    Aug 2011
    New Jersey, USA
    Posts
    19
    Points
    801
    Level
    It's good to add a heartbeat signal to every design to verify that the bit file loaded like FvM said. Just divide your clock to 2 Hz and have it clock a T flipflop and send that signal out to the LEDs. If you don't see your heartbeat, you have bigger problems than the DDS IP core
  18. #18
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    Germany
    Posts
    64
    Points
    2,104
    Level
    10
    [/COLOR]I just checked it that core is working perfectly but led is not glowing. Can you please tell me where the problem can be?
  19. #19
    Member level 3
    Join Date
    Dec 2011
    Posts
    62
    Points
    504
    Level
    If you have access to Chipscope, I would add an ILA core and see what's going on inside the FPGA.
    Quote Originally Posted by capcas View Post
    Cheers,
    Jim
  20. #20
    Points: 14,946, Level: 29
    mrflibble's Avatar
    Join Date
    Apr 2010
    Posts
    2,724
    Points
    14,946
    Level
    29
    Quote Originally Posted by rhearty1 View Post
    Quote Originally Posted by jimwu88 View Post
    Both good advice. A slow divided clock (2 Hz or some such) blinking a led is handy visual feedback during development. And chipscope is useful if you have to do some more invasive checking on the internals of your design. The blinky led is all of 5 minutes work, the ILA may be a little more work but will get you more debugging capabilities in return.
