+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Points: 176, Level: 2
    Join Date
    Feb 2012
    Posts
    7
    Points
    176
    Level
    Interfacing GPS module with RS232 with PIC 16F877A and transmit the received data
    Hello,
    How to interface GPS module with PIC 16F877A (MPLab IDE and HiTech C v9.8)
    my game plan is this
    * Receive the NMEA data from the GPS module baud rate 4800
    *Store it in a buffer in PIC 16F877A xtal 10MHz
    *Transmit the received dat via Bluetooth baud rate 4800
    here is the source code
    #include
    __CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
    unsigned char DATA;    //serial data buffer
    void interrupt isr(void)
      if(RCIF && RCIE)
        DATA = RCREG;
        if(TXIF)
          TXREG = DATA;
    void main(void)
      ADCON1 = 0x06;    //all port pins digital I/O mode
      TRISB = 0xff ;     // set PORTB as INPUT
      PORTD = 0 ;    //clear PORTD output latch
      TRISD = 0 ;     // set PORTD as OUTPUT
      TRISC = 0b11000000;  //PORTC output, RC6 UART TX, RC7 UART RX
      SPBRG = 0x81;    //baud rate 4800bps w/10MHz xtal
      TXSTA = 0x24;    //asynchronous serial mode, enable transmit, high speed BRG mode
      RCSTA = 0x90;    //enable serial port, enable continuous receive
      PIE1 = 0x20;    //enable serial receive interrupt
      INTCON = 0xC0;    //enable peripheral interrupts, enable global interrupts
      //main code begins here
    what i want to know is how to set up the hardware for this purpose dose my code work out or i need to change anything ?
    •   Alt18th March 2012, 11:53
      advertising
  2. #2
    Banned
    Points: 2,557, Level: 11
    Join Date
    Apr 2009
    Malaysia
    Posts
    330
    Points
    2,557
    Level
    11
    Re: Interfacing GPS module with RS232 with PIC 16F877A and transmit the received data
    See this GPS example code.
    1 members found this post helpful.
    •   Alt18th March 2012, 11:58
      advertising
  3. #3
    Join Date
    Feb 2012
    Posts
    7
    Points
    176
    Level
    Quote Originally Posted by engshahrul View Post
    I dont follow Malay anyway google translator is there :)
    btw is my code not useful at all ?
    •   Alt18th March 2012, 12:08
      advertising
  4. #4
    Banned
    Join Date
    Apr 2009
    Malaysia
    Posts
    330
    Points
    2,557
    Level
    11
    Quote Originally Posted by sanoopgr8 View Post
    What you mean your code not usefull? That is only a piece of code, just receive UART. You still need to processing that.
  5. #5
    Join Date
    Feb 2012
    Posts
    7
    Points
    176
    Level
    i just want to receive it and re-transmit it via bluetooth of same baud rate
    •   Alt18th March 2012, 16:34
      advertising
  6. #6
    Newbie level 5
    Points: 747, Level: 5
    Join Date
    Apr 2010
    Sri Lanka
    Posts
    9
    Points
    747
    Level
    you can do it.... just use RX pin to receive then TX to transmit through bluetooth. Do not forget to connect Ground for both.
