+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 5
    Points: 170, Level: 2
    Join Date
    Mar 2012
    Posts
    9
    Points
    170
    Level
    A problem dealing with RF power amlifier
    Hi everybody,
    I have faced a problem and would like to ask if you would possibly do me a favour. I have an electronic device named RF power amplifier 315 MHZ (made in China-PCR1A). The problem is dealing with its range to get the frequency from the receiver. I mean itís not good enough and I would like to improve its range by replacing some elements-of course if itís possible!. I also would like to mention that itís not possible for me to change the whole device. I would appreciate if an expert will help me. Iím really bored out of mind! :(
    Thank you. :)
    •   Alt13th March 2012, 17:11
      advertising
  2. #2
    Advanced Member level 5
    Points: 16,136, Level: 30
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    Re: A problem dealing with RF power amlifier
    Quote Originally Posted by mona.rosa View Post
    Hi everybody,
    Thank you. :)
    It is nice that you ask for advice, but so far there is nothing anybody can do for you. Please indicate technical specifications to which one may comment. A receiver can receive signals at certain frequency but you do not write anything about it.
    2 members found this post helpful.
    •   Alt13th March 2012, 18:32
      advertising
  3. #3
    Points: 37,620, Level: 47
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    PCR1A is a very low cost RF receiver can be used to receive signal up to 100 meters.
    In this case the antenna design and working environment may seriously impact the effective distance.
    In my opinion you cannot change the power on the transmitter side, or increase the sensitivity for the receiver unit.
    1 members found this post helpful.
      advertising
  4. #4
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    I still do not see any TECHNICAL specification to consider.
  5. #5
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    Put a Yagi aerial on both devices, bit big at this frequency but will increase the distance of reception.
    Frank
    •   Alt13th March 2012, 18:53
      advertising
  6. #6
    Newbie level 5
    Join Date
    Mar 2012
    Posts
    9
    Points
    170
    Level
    Quote Originally Posted by mister_rf View Post
    Hi
    Thank you for your reply. It's not really up to 100 meters! It would be good enough if it was so! :)
    I would like to mention that we are working with a micro controller 89s52 too, and it has some noises. Do you think is there any possible way to remove this noise, since as you know it decreases the power of receiving?
    ---------- Post added at 20:39 ---------- Previous post was at 20:17 ----------
    Quote Originally Posted by chuckey View Post
    Frank
    thank you for your reply. Honestly, I don't know what Yagi aerial is?! you mean antenna?
  7. #7
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    So far you put no technical specifications for anyone to help you. Now you even do not know what a Yagi antenna is. Go to a library and find some basic textbook on radio. You need it very much!
  8. #8
    Newbie level 5
    Join Date
    Mar 2012
    Posts
    9
    Points
    170
    Level
    Quote Originally Posted by jiripolivka View Post
    I put some information here.
    http://www.edaboard.com/thread244380.html#post1045558
