+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Member level 1
    Points: 458, Level: 4
    Join Date
    Mar 2011
    Posts
    39
    Points
    458
    Level
    Difference: Dielectric and Insulator?
    What is the difference between the terms insulator and dielectric? what do they mean?
    Is capacitor as a whole a dielectric or the air between the plates alone called dielectric? And how is semiconductor related to either dielectric of insulator??
    thanks in advance!
    •   Alt12th March 2012, 12:00
      advertising
  2. #2
    Full Member level 2
    Points: 2,286, Level: 11
    Achievements:
    7 years registered
    Join Date
    Dec 2009
    Russia
    Posts
    131
    Points
    2,286
    Level
    11
    Re: Difference: Dielectric and Insulator?
    no difference
    A semiconductor have electrical conductivity intermediate between a conductor and an insulator.
  3. #3
    Points: 9,431, Level: 23
    FoxyRick's Avatar
    Join Date
    Jan 2004
    England, UK
    Posts
    1,245
    Points
    9,431
    Level
    23
    The term 'dielectric' tends to be used for an insulator that is used where it can be polarized by an electric field, as in a capacitor, and where that is important to the function or needs taking account of.
    It is also applied more to materials that have a high ability to be polarized, if talking about the materials themselves.
  4. #4
    Member level 1
    Join Date
    Mar 2011
    Posts
    39
    Points
    458
    Level
    Is it then right to say an insulator always remains a "non-conductor" of electricity/heat, Whereas a dielectric can store charge if maintained at the right potential??
    ANd so is Air an insulator or dielectric?
    •   Alt13th March 2012, 14:05
      advertising
  5. #5
    Full Member level 2
    Achievements:
    7 years registered
    Join Date
    Dec 2009
    Russia
    Posts
    131
    Points
    2,286
    Level
    11
    "A true insulator is a material that does not respond to an electric field and completely resists the flow of electric charge. In practice, however, perfect insulators do not exist. Therefore, dielectric materials with high dielectric constants are considered insulators." (from wiki)
    Air is a dielectric.
    •   Alt13th March 2012, 14:11
      advertising
  6. #6
    FoxyRick's Avatar
    Join Date
    Jan 2004
    England, UK
    Posts
    1,245
    Points
    9,431
    Level
    23
    "Insulator" or "Dielectric" depends largely on the context in which the material is being discussed.
    Mica is a very good electrical insulator - it is often used as such in heat sink mountings. It is also used as the dielectric in mica capacitors. So, which is it? Both, depending on the context. So is air.
    1 members found this post helpful.
  7. #7
    Full Member level 6
    Points: 2,584, Level: 11
    Join Date
    Mar 2012
    Posts
    338
    Points
    2,584
    Level
    11
    gauthamtechie,
    An insulator is a substance that holds onto its valance electrons tightly, so very few charge carriers are available to support conduction. A dielectric is capable of being polarized, i.e., one side of its molecule has a different charge than the opposite side. This forms a electrostatic dipole that increases the capacitance of a capacitor. Those terms are not interchangable. A dielectric must also be an insulator within its voltage range or the cap is considered "leaky". I don't know of any really good insulators that are also really good dielectrics.
    thanks in advance! .
    As a whole, no. A cap has plates, leads and a protective coating besides a dielectric. A vacuum, also known as "free space", has a relative dielectric constant (also known as relative permittivity) of 1. The dielectric of vacuum is the standard for which other materials are compared. Air has a dielectric constant close to 1, mica is 6.0. A material that polarizes easily makes a better dielectric. In a parallel plate capacitor, the capacitance is directly proportional to the dielectric constant.
    A semiconductor is ultra pure crystalline silcon to which a controlled relatively small amount of "dopant" is added. This makes it conduct it better than a insulator but less than a metallic conductor. It would not be a very good dielectric because it would leak badly. It goes beyond the scope of your question to discuss semiconductors further.
    ANd so is Air an insulator or dielectric? .
    Any insulator will pass a minute amount of charge if the voltage is high enough. A dielectric does not store charge. As part of a capacitor, it stores energy. The amount of charge carriers in a cap at 100 volts is the same as at 0 volts, but the energy stored is much higher. A capacitor is never "charged", it is energized.
    poluekt ,
    Nope, the dielectric constant and conductivity are two independant parameters. If Wiki said that, they are wrong. A high dielectric constant means the material polarizes easily.
    Air is a good insulator, but not much better than vacuum for dielectric constant value.
    Ratch
  8. #8
    Member level 1
    Join Date
    Mar 2011
    Posts
    39
    Points
    458
    Level
    thank you, that has clarified many things.
    Also, i just want to know if i got this right:
    Quote Originally Posted by Ratch View Post
    This is something that's new to me: You're saying capacitor does not store charge? But then i've heard about these terms "capacitor discharges" et al. Oh so then May i presume by "discharging", They mean it becomes "de-energized"?
    Finally, you are saying in a capacitor, some "x" coulombs of charge is present at any voltage. And at 100 volts, what becomes higher is not the "coulombs" but the "workdone" which is Joule per coulomb (J/C) ,right?
  9. #9
    Full Member level 6
    Join Date
    Mar 2012
    Posts
    338
    Points
    2,584
    Level
    11
    gauthamtechie,
    Correct, its net charge remains zero before and after any voltage is applied. Before any voltage is applied, the charge difference between the plates is zero. After applying any voltage, there is a charge difference between the plates, but the net charge is still zero. The excessive charge on one plate is balanced by a deficient charge on the opposite plate for a net charge change of zero. It takes energy to separate the charges, and anytime unbalanced charges are present, an electrostatic field is formed. The energy or work it took to separate the charges is stored in the electrostatic field.
    Yes, and you heard NASA saying that they "walk" in space, too. You've seen video of astronauts outside their spacecraft. Are they walking?
    That is 100% correct.
    The charges on the plates of a cap are either in balance with each other, or there is a difference as explained above.
    And at 100 volts, what becomes higher is not the "coulombs" but the "workdone" which is Joule per coulomb (J/C) ,right? .
    There would be a coulomb difference between the plates of the cap. Joules/coulomb is the energy density of the charge, or voltage. So both the voltage and energy of the capacitor increase, and the net charge stays the same.
    Ratch
    •   Alt7th April 2012, 13:37
      advertising
  10. #10
    Member level 1
    Join Date
    Mar 2011
    Posts
    39
    Points
    458
    Level
    You've nailed it
    Are you a professor ?
  11. #11
    Full Member level 6
    Join Date
    Mar 2012
    Posts
    338
    Points
    2,584
    Level
    11
    guanthamtechie,
    You've nailed it
    It is all a matter of disregarding the false jargon. Otherwise descriptions get confused. In physics, it helps to use precise explanations and disregard analogs unless you are trying to make a point.
    No, I just try to arrange facts so they make sense.
    Ratch
