+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
  1. #1
    Junior Member level 1
    Points: 632, Level: 5
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    amplify the signal output of the 555 timer
    how would you amplify the output signal of a 555 timer without distorting the signal? i tried using a bc547 transistor and the output voltage is increased from 150 mV to approximately 700 mV. I want the output to be around 2-3V. Also the amplified output signal from the transistor became distorted and is not the 40kHz pulses that I wanted anymore. any suggestions?
    thanks a lot
  2. #2
    Super Moderator
    Points: 49,672, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Re: amplify the signal output of the 555 timer
    There is something wrong with what you have built if you only get 150mV out of the 555. Show your schematic.
    Keith
    I started life with nothing and I've still got most of it left. (Seasick Steve)
    •   Alt27th February 2012, 17:15
      advertising
  3. #3
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    Click image for larger version.
Name:	555 timer.png
ID:	69814 there, that is the schematic. thanks for your reply
  4. #4
    Advanced Member level 5
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hello
    At first i agree with keith . and at second , how much is the value of your VCC ? and if you want it's square wave out put , you shouldn't use a simple transistor . you should use a totem pole . because of the bad behavior of single transistor at this case .
    Regards
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
  5. #5
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    hi, thanks vcc is at 5 volts and my circuit is the same except that i didnt use a button to the output. can you please elaborate what a totem pole would do? thanks for the reply.
  6. #6
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    The totem pole is simply 2 transistor that combined together , a first transistor will charge the load ( give it voltage ) and another will discharge it ( will connect it to the ground when the time of operation is over . and it will provide a good square wave .
    and you should increase the supply voltage . e.g about 10 volt.
    Regards
    Goldsmith
  7. #7
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    Quote Originally Posted by goldsmith View Post
    Regards
    Goldsmith
    thanks for your reply goldsmith, is it ok if u can give a website or post an example schematic of a totem pole transistor configuration? it seems that there is not a lot on google. i might keep the supply voltage to 5V i think for convinience and the 555 timer is powered by 5 volts anyway.
    thanks again
  8. #8
    Points: 37,620, Level: 47
    mister_rf's Avatar
    Join Date
    Feb 2008
    Romania
    Posts
    1,874
    Points
    37,620
    Level
    47
    See here:
    2 members found this post helpful.
    •   Alt27th February 2012, 18:07
      advertising
  9. #9
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    I don't see the relevance of discussions of totem pole circuits. The 555 can source 100mA from 5V supply although you will only get around 3V peak not 5V. I think you have to look for building errors, short circuits etc. The only thing I can see that is wrong is the missing 10nF that should be on the control voltage pin.
    Keith
    •   Alt27th February 2012, 18:17
      advertising
  10. #10
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    See below please:
    Push
    Dear Keith
    As we know if he try to amplify the square wave with a single and simple transistor , the out put will have large value of DC ( will shift up more than past ) . and if we use a totem pole . all things will be right .
    Regards
    Goldsmith
    1 members found this post helpful.
  11. #11
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Goldsmith,
    While he is trying to amplify the signal from the 555, the signal is not correct in the first place. It should need no amplification. It should be more than 150mV. The true cause of the problem needs finding and fixing.
    Keith
  12. #12
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Dear Keith
    Yes i'm agree with you . i didn't see this very low value of amplitude for 555 IC until know and i think a mistake is occurs with his circuit building .
    Regards
    Goldsmith
  13. #13
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    thank you for all your replies again. i shall double check my circuit and find the fault in it. i will update this post once i've found a fault. thanks again to goldsmith, keith and mister_rf. should i just rebuild the same circuit that i posted on here or any of you guys have a suggestion for a better 555 timer circuit? if so can u please post the schematic on here? thanks again for your help
  14. #14
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    The circuit is fine. If you powered it from more than 5V then you would have more accuracy in setting the LED current, although that could be improved at 5V with a single transistor buffer if required anyway.
    Keith
  15. #15
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    Quote Originally Posted by keith1200rs View Post
    Keith
    ok thanks. i tried increasing vcc to 7V but the output signal pulses get distorted, what ever value i change the potentiometer to, the frequency would not change at all.. so i think the circuit is optimised for 5 V. are u suggesting that i shud use a buffer for the output of the IC? or to increase vcc? i just use a power supply for the vcc so using a transistor is not necessary to increase it.
  16. #16
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Agai Hi
    What is your load resistance ? perhaps it is higher than the allowable value . or maybe your IC isn't intact . try to change your IC
    Regards
    Goldsmith
  17. #17
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Try the circuit with no load and see if it works OK then.
    Keith.
  18. #18
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    hi, i realised the mistake, and i corrected it, the output voltage is now 1V Vpp but i dont think the current this time is high enough, because when i use my camera to see how bright the led is, its barely lit. I used Vcc as 9V as suggested as well. My setup now has no load resistance. When I tested it, with my receiver circuit, the receiver detects the pulsed ir output occasionally. what can u guys suggest to increase the output current this time? to make the IR LED brighter , hence emit more IR radiation? thanks for your replies
    •   Alt28th February 2012, 11:53
      advertising
  19. #19
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Are you using this to drive an LED for a camera light source? If so, why? You will get aliasing between the camera shutter speed and the LED modulation. Simply drive the LEDs continuously. Also, what colour are your LEDs and is it a monochrome camera? White LEDs have a high forward voltage.
    Keith
  20. #20
    Join Date
    Feb 2012
    Posts
    19
    Points
    632
    Level
    no im not using it to drive an led for a camera. im creating an ir emitter and receiver circuit. im using my camera to see how bright the ir emitter is because i cannot measure the current through it. another weird thing i found is that with my current set up the ir emitter led only works when connected in reverse polarity, meaning the long side of led to ground and short side to the output of 555 timer. if i connect it the other way the circuit gets shorted. im not too sure why.
