Help me write code for distance measurement using ultrasonic transducer & PIC16F877A
maximus332
Sir,
I am working on a distance measurement device using PING ultrasonic transducer and PIC16f877A,
but i cant able write the suitable code for this sensor in C, please help me.
Thanks
Re: distance measurement
Are you talking about this sensor? www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
The theory of operation is explained in page 3 of the document. For measuring the width of the signal, you can use the capture module.
Hope this helps.
Tahmid.
pls send me the code for distance measurement using PIC1687x and PING ULTRASONIC transducer,
my email id : maximus332@rocketmail.com
thank you.
i want to measure the distance to an object up to 3m, i am using PIC16f877A as the controller, pls check the attachment which is the data sheet of my sensor.
thank you.
  • TS601-01.pdf
Re: Help me write code for distance measurement using ultrasonic transducer & PIC16F8
i'm just working on a one ...
my idea based on using pwm .. as i emit pwm with freq. 40khz from the pic for 0.5 sec..then through the transiver . that's meaning 20khz has been transmitted at the same time i open the pwm i
use the pic in capture mode to count the number of returned pulses through the receiver ...
then i calculate the number of missed pulses ... 20k - recevied = missed .... then by knowing the frequency we can calculate the distance
plllllllllllz i need a code in C also for the same project... measuring height by LV-EZ0 sensor....and im using pic16f8877a ...
The following is a document with a detailed discussion of using several of the available interfaces of the MaxBotix LV-MaxSonar series with a PIC with code snippets.
BigDog
