+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 6
    Points: 308, Level: 3
    Join Date
    Jul 2011
    Posts
    12
    Points
    308
    Level
    Error 628 connection terminated by remote computer
    Hi There
    What causes "Error 628: Connection terminated by the remote computer before it could be completed so the port used was closed"
    I have been using a huawei E220 HSDPA usb modem to connect to internet but recently since I started seeing this error from the modem I have failed to use it to connect to internet.
    I have the right settings from my service provider such as the APN, I have data on my data card. my modem has never got any physical damage, I tried to use the modem on other computer not mine alone but still the same message comes.
    I contacted the huawei website but I found no solution. Please help me out before I consider buying another modem. I believe there is a solution to this.
    •   Alt16th February 2012, 07:04
      advertising
  2. #2
    Advanced Member level 3
    Points: 7,839, Level: 21
    Achievements:
    7 years registered
    yadavvlsi's Avatar
    Join Date
    Nov 2010
    Bangalore, India
    Posts
    977
    Points
    7,839
    Level
    21
    Re: Error 628 connection terminated by remote computer
    •   Alt7th March 2012, 13:39
      advertising
  3. #3
    Super Moderator
    Points: 10,500, Level: 24
    Achievements:
    Created Blog entry 7 years registered
    Join Date
    Jul 2007
    Sri Lanka
    Posts
    1,563
    Points
    10,500
    Level
    24
    Blog Entries
    maybe the service provider disconnect your line
    did you call them?
    •   Alt7th March 2012, 16:22
      advertising
  4. #4
    Newbie level 6
    Points: 182, Level: 2
    Join Date
    Mar 2012
    Posts
    13
    Points
    182
    Level
    Hello
    Here are some solutions to this problem....
    1 Reinstall the modem.
    2.Confirm that you have good phone line.
    3.Check the router/firewall settings.
    4.Re-enable RAS.
    5. Check that you are using correct username or password.
  5. #5
    Newbie level 1
    Points: 110, Level: 1
    Join Date
    May 2012
    lucknow
    Posts
    Points
    110
    Level
    I am also using this same data card so to solve this problem you need to change the setting in the properties of your network :-just three steps ahead
    1. click on the network icon present in the task bar & find your broadband setting.
    2. Right click on that setting and select properties.
    3.Click on security tab and change the data encryption setting to any other setting except "require encryption" setting.
    TRY THIS!!!!!!!
    If this does not work
    Then you need to change the data card.
