+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 3
    Points: 987, Level: 7
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    How to assign PML in HFSS
    Dear all,
    I am trying to simulate a Frequency Selective Surface in HFSS, for which i require to assign PML to the designed structure.
    Can anyone let me know how to assign PML to the FSS design.
    Thanks!
    Arslan.
  2. #2
    Full Member level 6
    Points: 3,554, Level: 14
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    US
    Posts
    350
    Points
    3,554
    Level
    14
    Re: How to assing PML in HFSS
    For assigning a PML boundary to any surface in HFSS: select the face,right click and select assign boundaries: you should select PML setup wizard, in the PML setup : change the minimum frequency for your design. Make sure the Master/Slave boundaries include the PML. That's all.
    Generally, for designing FSSs is HFSS, you can go with three options:
    1) Using Perf E and Perf H boundaries
    2) Using Master/Slave boundaries with PML setup and Plane wave excitation
    3) Using Floquet ports.
    There are lot of tutorials online which give detailed instructions on how to design FSSs in HFSS.
    -sv
    2 members found this post helpful.
    •   Alt16th February 2012, 02:55
      advertising
  3. #3
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    Thank you so much for the reply.
    I am doing it by using option 2 as you mentioned above. But the problem is that
    i'm not able to get the Transmission and Reflection plot according to the desired requirement.
    Even Floquet ports are not giving the right results. I think i am making some sort of mistake as i don't know the
    exact way to assign the boundaries.
    •   Alt16th February 2012, 09:42
      advertising
  4. #4
    Full Member level 6
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    US
    Posts
    350
    Points
    3,554
    Level
    14
    Hi Arxlan,
    Which FSS structure are you planning to design ? I can design it for you and send you the HFSS project.
    -sv
    1 members found this post helpful.
  5. #5
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    Hello,
    Thats so nice of you. I'm trying to validate paper titled "Single-Layer High-Order Miniaturized-Element Frequency-Selective Surfaces", In this paper three
    designs have been presented, but i'm simulating the Design#1 to get familiar with Transmission and Reflection Characteristics.
    Should i provide you with the HFSS file i already tried or you will simulate by yourself?
    •   Alt17th February 2012, 05:21
      advertising
  6. #6
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    @sv1437
    I think i twill be easier for you to look at the file i simulated and modify it so that i can get my desired results.
  7. #7
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    When i simulate it using Master/Slave boundaries with PML setup and Plane wave excitation, following warning pops up
    and in the end some random results obtained. Not like the one i want to get.
  8. #8
    Full Member level 6
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    US
    Posts
    350
    Points
    3,554
    Level
    14
    Hi Arxlan, Is it Fig. 2 in the paper ?
    -sv
  9. #9
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    Hello,
    Yes the Unit cell is shown in Figure 2 and the Design parameters are given in Table 1.
    I am still working on it but not able to simulate it successfully.
    Hope you will do it and let me know what i;m doing wrong.
    Regards,
    Arslan
  10. #10
    Full Member level 6
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    US
    Posts
    350
    Points
    3,554
    Level
    14
    Hi arxlan,
    I am attaching the HFSS design. As I mentioned earlier there are three ways to design FSS structures. Generally, if the FSS structure is symmetric, perf E/perf H option is easy and faster. It takes very less simulation time. So I simulated the structure with variable capacitor. And was able to reproduce Fig. 6.
    In the paper, the author did not mention the length of the wire loop. So I used 3.9mm
    If you still want the design with PML boundaries, let me know.
    -sv
    •   Alt25th February 2012, 17:07
      advertising
  11. #11
    Member level 3
    Join Date
    Oct 2011
    Posts
    67
    Points
    987
    Level
    7
    Hello,
    Thank you for the attachment. I will analyze and try to achieve the exact results as shown in Fig 6.
    Hopefully i will succeed in doing that.
    Before that i was trying to do it using PML boundaries, but i think first i should analyze using perf E/perf H.
    Will let you know soon.
    Thanks again,
    Arxlan.
  12. #12
    Newbie level 3
    Points: 1,097, Level: 7
    Join Date
    Aug 2008
    Posts
    Points
    1,097
    Level
    7
    Hi
    I have problem with getting the S parameter of a rectangular wave guide whose boundaries in x an y direction is PML. there are some tutorials about how to assign PML and they use incident wave excitation , However since I need S parameter I should have 2 ports. Considering a simple air wave guide which ideally should have 1 S21 in frequency domain. but it does not. I think I may have problem in assigning a proper port. i would be appreciated if any one guide me.
