+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Junior Member level 2
    Points: 175, Level: 2
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    Programming of 8051 with LCD,Proximity switch and keybord
    Hello everyone....
    I am working on my project of making a digital length counter, where i have to interface LCD,keyboard and proximity switch....
    The input from the keyboard is to be displayed on the LCD & also given to the microcontroller...
    I want to know how should i do the programming in 8051,as one is the LCD interfacing program and the other is keyboard interfacing program.
    Merging of the programs is to be needed? or i have to just write the program as it is??
    I even don't know how to write the program to interface proximity switch....
    The proximity switch m using is of NPN type NO, voltage 5-40VDC,max load 200mA...
    Pls help me out with all my queries....
    Thankyou..
  2. #2
    Full Member level 2
    Points: 1,677, Level: 9
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    Re: Programming of 8051 with LCD,Proximity switch and keybord
    please tell me that in which language do u wnt to programming?
  3. #3
    Advanced Member level 3
    Points: 5,481, Level: 17
    Join Date
    Apr 2011
    Posts
    926
    Points
    5,481
    Level
    17
    please post your Lcd and keypad code and your schematic.
    •   Alt6th February 2012, 08:48
      advertising
  4. #4
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    Quote Originally Posted by jignesh doshi View Post
    Which language according to you is easy? Sorry but i have no idea about what to use... Does it depend on output?
    ---------- Post added at 16:47 ---------- Previous post was at 16:25 ----------
    sorry but schematic is not ready as on which pin the LCD,sensor and keypad is to be connected is not known to me.... and i have 16 x 2 LCD , keypad is 4 x 3...
  5. #5
    Full Member level 2
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    actually have u knowledge of basic in programming in C or assembly?
    from this answer any1 can give his suggestion 2 u...
    and also tell me k have u interfaced LCD and Keypad before?
  6. #6
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    I have the knowledge of assembly more than c
    And no i have not interface LCD and keypad before
    •   Alt6th February 2012, 12:23
      advertising
  7. #7
    Full Member level 2
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    ok...
    so u can easily go to the assembly...
    and first of all u have to learn that hw to interface LCD and keypad with 8051,after u can think about proximity...
    so in interfacing of lcd and keypad if u want any help then i can....
    •   Alt6th February 2012, 12:24
      advertising
  8. #8
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    I have the knowledge of programming in assembly more than that in c
  9. #9
    Full Member level 2
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    i have changed my last post...so please check it....
  10. #10
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
  11. #11
    Full Member level 2
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    so first of all u must have to knowledge of LCD and Keypad interfacing...so try these two and in these if u required any help then i m here...
  12. #12
    Points: 7,837, Level: 21
    milind.a.kulkarni's Avatar
    Join Date
    Oct 2011
    Bangalore
    Posts
    923
    Points
    7,837
    Level
    21
    Blog Entries
    In my view Nidhitrivedi,
    If you know the assembly better to learn embeeded C ....As C is very commonly used language on embeeded platform.....also once u learn C coding for processors ....It more or less same for almost all the devices....in case of assembly one need to study the insturction set if the device is changed....also lot of material for LCD and counter code is avalible on net in C
    refer this links -
    http://www.edaboard.com/thread138647.html
    Good Luck
    Hope the post will be helpful to you....
    "Sharing is the best way of Learning"
  13. #13
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    M sorry i just saw that...
    I have gone through Mazidi and learnt about interfacing LCD and Keypad... actually my main project is about digital length counter where i have to take the required length input from the customer, now this input must be displayed on the LCD and also it should be given in the microcontroller for future calculation...
    The future calculations are based on the proximity switch(it gives the output in form of pulses). so i want to make such a program that counts the no.of pulses required for the customers required length and then stops the machine as the required length is achieved.
    ---------- Post added at 17:10 ---------- Previous post was at 17:06 ----------
    Hey thankyou so much... I will surely refer that....
  14. #14
    Full Member level 2
    Join Date
    Aug 2011
    Posts
    129
    Points
    1,677
    Level
    9
    ohk...but to display the length u have to connect LCD with MC so i told to interface that and get full knowledge that hw to interface LCD with MC...so u cn execute ur project easily...
    so have u knowledge of LCD interfacing?
  15. #15
    Join Date
    Oct 2011
    Bangalore
    Posts
    923
    Points
    7,837
    Level
    21
    Blog Entries
    This will be helpful to you....I think....I dose not understand your requirement / Calculation correctly-
    [HELP] c code to count frequency pulses and display on LCD [8051/52] : 8051 Microcontroller Projects AVR PIC Projects Tutorials Ebooks Libraries codes
    Good Luck
  16. #16
    Advanced Member level 1
    Points: 2,012, Level: 10
    dselec's Avatar
    Join Date
    Jan 2012
    Posts
    451
    Points
    2,012
    Level
    10
    Best way is to use interrupt for detecting the prox.. and then internal timer will count the next interrupt from prox..
  17. #17
    Join Date
    Feb 2012
    Posts
    20
    Points
    175
    Level
    Quote Originally Posted by milind.a.kulkarni View Post
    Good Luck
    Actually i m working on a project for a cord manufacturing company and hence for their purpose of use i want to develope a microcontroller based project in which the required length input from the customer is taken and that input must be displayed on the LCD and also it should be given in the microcontroller for future calculation...
    •   Alt6th February 2012, 13:19
      advertising
  18. #18
    Join Date
    Apr 2011
    Posts
    926
    Points
    5,481
    Level
    17
    Frequency Counter using AT89C2051 and LCD (Assembly) : 8051 Microcontroller Projects AVR PIC Projects Tutorials Ebooks Libraries codes
    2x16 LCD And 4x4 Keypad Interfacing With 8051 in Assembly Language | bOtskOOl
    Assembly Language program for LCD code ~ Micro-Controller 8051: data acquisition and control system
    refer to any above link it may help you
    1 members found this post helpful.
  19. #19
    Banned
    Points: 157, Level: 2
    Join Date
    Feb 2012
    Posts
    Points
    157
    Level
    Estimates of how many people will not
    diablo 3 gold
