+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Newbie level 5
    Points: 303, Level: 3
    Join Date
    Jun 2011
    Posts
    9
    Points
    303
    Level
    battery model in simulink matlab
    hii .. I need to do a battery model in simulink, i found the model of a particular battery in a conference paper . i m unable to make it in simulink.. plzz help me with the current-current blocks and the 1/u blocks. thanku.. plzz reply fast.. thanks a lot... :)
    •   Alt4th February 2012, 19:18
      advertising
  2. #2
    Full Member level 2
    Points: 1,638, Level: 9
    Join Date
    Dec 2011
    Posts
    146
    Points
    1,638
    Level
    9
    Re: battery model in simulink matlab
    The 1/u block is just the reciprocal: f(u) = 1/u.
    The voltage-voltage block contains the non-linear function between SOC (state of charge) and output voltage.
    It depends on the battery type - may be something like: 1.2 + 0.1*SOC - 0.01*SOC^2 etc...
    Without accurate knowlegde of this block the model is useless.
    P.S. Rts/Cts and Rtl/Ctl model short and long constant transients
    1 members found this post helpful.
  3. #3
    Newbie level 5
    Join Date
    Jun 2011
    Posts
    9
    Points
    303
    Level
    Quote Originally Posted by dave9000 View Post
    thanks for replying.. :)
    I m not sure about the details of the model given in the paper .. some data seems to be missing but i m unable to figure out how to proceed can u plz help me.. to knw whether this paper can be implemented without the practical values.. thanks a lot..
    p.s link: http://power.ece.drexel.edu/Students...%20Testbed.pdf
    my request seems to be silly but plzz help me.. i dnt knw how to procedd in designing a battery model in matlab for hybris system applicaitons... thanks a lot..
    •   Alt5th February 2012, 05:33
      advertising
  4. #4
    Full Member level 2
    Join Date
    Dec 2011
    Posts
    146
    Points
    1,638
    Level
    9
    It's a good paper. You can find most of the data that you need from the graphs!
    For example you find: Rts, Cts, Rtl, Ctl, full charge Vout, etc...
    Start with a first order model (Vout=4.1-alpha1*SOC) and find a good alpha1 from the simulations (match some discharge plot)...
    •   Alt5th February 2012, 09:07
      advertising
  5. #5
    Newbie level 5
    Join Date
    Jun 2011
    Posts
    9
    Points
    303
    Level
    sorry for asking so many times.. but could u please elaborate a little..
  6. #6
    Newbie level 1
    Points: 110, Level: 1
    Join Date
    May 2012
    Posts
    Points
    110
    Level
    sorry for the bump, but I have the exact same problem. @chd123 did you manage to simulate the model after all? Some help would be nice..I found the relation between the VOC and SOC from another paper, but when I simulate this the current is zero so everything is zero.. any ideas?
    Thx in advance..
  7. #7
    Newbie level 1
    Points: 70, Level: 1
    Join Date
    Aug 2012
    Posts
    Points
    70
    Level
    hi, i'm using simulink R2010a which has a battery in the library. I'm working on a grid energy storage model where the storage model control system is meant to check the network voltage (p.u) and then do one of the following;
    1] discharge the battery if the voltage is low i.e. below a specified limit of say 0.94 or
    2] charge the battery if the voltage is high i.e. above a specified limit of say 0.97 so as to restore the voltage between the predefined limits or
    3] take no action
    Could i get some help in designing the system. thanx
    •   Alt2nd August 2012, 04:16
      advertising
  8. #8
    Newbie level 6
    Points: 1,124, Level: 7
    Join Date
    Jun 2007
    Posts
    14
    Points
    1,124
    Level
    7
    HI hope you are well,
    why do not use the model provided by Matlab, i do not understand why you are trying to develop your own model, see you can implement the simuklink model from the Matlab without being worried about the battery model,
  9. #9
    Newbie level 1
    Points: 19, Level: 1
    Join Date
    Apr 2013
    Posts
    Points
    19
    Level
    Quote Originally Posted by nuflia View Post
    I work on the modeling of Li-ion battery, and I want implement the model provided by MATLAB but I dont know what block used to implement the function of charge and discharge[ATTACH=CONFIG]88972[/ATTACHClick image for larger version.
