LM35(Temperature sensor) -> PIC18F4550 -> RT1602C(LCD)
kwanchong
Newbie level 5
Im working on a project which i want to send the output of LM35 to an internal ADC in the PIC18F4550 micro-controller and then display it on the RT1602C 2x16 LCD. Iam given to use the MPLAB IDE v8.63 C18 compiler.
Analogue input from LM35 will be at AN0/RA0
LCD will be receiving 4-bit data, Ports to LCD from micro-controller will be from PORTD.
Can someone provide the codes for programming the ADC & send data to LCD?
I'm totally new to the C18 compiler..
Thanks in advance.
Hi thannara123,
I have seen the post but it uses the Hi-tech C compiler and I do not know how to convert languages. The compiler I am using is the C18 compiler.
Thanks
Is it okay if you can copy and paste the code with the corrected codes? I do not really understand what https://www.edaboard.com/threads/214672/ is talking about.. as for the other link, I cannot get access to that Temperature sensor. I have only the LM35.
Thanks
The compiler used is: HI-TECH C Compiler for PIC18 MCUs
The compiler i am using is: C18 Compiler
