+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 4
    Points: 1,738, Level: 9
    W_Heisenberg's Avatar
    Join Date
    Feb 2011
    Boston
    Posts
    217
    Points
    1,738
    Level
    9
    How does diffraction grating work?
    As the title, how does this work?
    Every word or concept, clear as it may seem to be, has only a limited range of applicability.
    •   Alt31st January 2012, 07:11
      advertising
  2. #2
    Advanced Member level 3
    Points: 7,839, Level: 21
    Achievements:
    7 years registered
    yadavvlsi's Avatar
    Join Date
    Nov 2010
    Bangalore, India
    Posts
    977
    Points
    7,839
    Level
    21
    Re: How does diffraction grating work?
    •   Alt31st January 2012, 07:15
      advertising
  3. #3
    Full Member level 4
    Join Date
    Feb 2011
    Boston
    Posts
    217
    Points
    1,738
    Level
    9
    Yes, I already read this.
    Yet I still can not understand that how this thing works in dispertion?
    Can you explain this for me somehow?
    Thanks in advance
    •   Alt31st January 2012, 07:59
      advertising
  4. #4
    Super Moderator
    Points: 239,557, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    Dispersion?
    I think that the Diffraction formalism - Wikipedia, the free encyclopedia article has a more visual explanation when referring to double slits, although not explicitely discussing the difference to multi-slits or gratings.
    But effectively, it's all in the expression
    a sinθ = nλ
  5. #5
    Full Member level 4
    Join Date
    Feb 2011
    Boston
    Posts
    217
    Points
    1,738
    Level
    9
    does this imply that only certain wavelength can diffraction from the slits?
    That is to say, wavelength represents certain wave, or in other words, certain frequency, so that it select the frequency from the light wavepackets after the slits.
    If so, samely for grating, then.
    Maybe this is the way it works in dispertion of lights.
    Thanks man, you point this out for me!
    Sincelry
    •   Alt1st February 2012, 06:55
      advertising
  6. #6
    Points: 17,009, Level: 31
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    ---> Hike with wise men , then you will be wise <---
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    Literally, the ability of a diffraction grating to separate light of different wavelength is not based on dispersion. At least in the usual understanding, dispersion is a frequency dependency of phase velocity. A prism monochromator e.g. utilizes dispersion.
    The chromatic separation of diffraction grating is based on interference. A mathematical explanation can be found here:
    Fraunhofer diffraction (mathematics) - Wikipedia, the free encyclopedia
