+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 503, Level: 4
    Join Date
    Jul 2010
    Posts
    19
    Points
    503
    Level
    How to split S-parameters into two symmetric halves? For de-embedding.
    I'm trying to characterize a WR90 waveguide-to-coaxial adapter thru the VNA by attaching it to an identical pair. So the coaxial ends of each adapter are connected to the VNA ports while the rectangular ends are connected against each other. Now I measured the full S-parameters for these symmetric pair, now my problem is how can I split this result to represent the S-parameter for each adapter? Anyone who have done this before?
    •   Alt26th January 2012, 21:30
      advertising
  2. #2
    Points: 7,835, Level: 21
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Italy
    Posts
    1,087
    Points
    7,835
    Level
    21
    Re: How to split S-parameters into two symmetric halves? For de-embedding.
    S-parameters cannot be directly cascaded. You have to transfom it to T parameters that are cascadable. A procedure could be:
    1. measure the S parameter of the fixture (Sfix) i.e. left and right halves connected toghether
    2. transform to Sfix into T matrix Sfix ==> Tfix
    3. we know that Tfix = Tleft*Tright
    4. set Tleft = [T11 T12, T21 T22] and Tright = [T22 T21, T12 T11]
    5. furthermore T21 = T12
    6. from Tfix apply some math to calculate T11, T22 and T21
    7. with DUT you will have Ttot = Tleft*Tdut*Tright
    8. Tdut = Tleft-1*Ttot*Tright-1
    9. transform back Tdut ==> Sdut
    I hope can help
    •   Alt26th January 2012, 23:07
      advertising
  3. #3
    Join Date
    Jul 2010
    Posts
    19
    Points
    503
    Level
    Thanks for the reply. I got a problem with the #4 though. So if I have a connected symmetric DUT such that Sleft = [S11 S12; S21 S22] and Sright = [S22 S21; S12 S11], does converting Sleft->Tleft=[T11 T12;T21 T22] make the Tright=[T22 T21; T12 T11]??
    It's the S-parameters of my left and right component that should be mirrored, not the T-parameters right?
    ---------- Post added at 11:06 ---------- Previous post was at 09:34 ----------
    Ok after some math manipulation, I derived that an [S11 S12; S21 S22] conversion to [T11 T12; T21 T22] would make its counterpart [S22 S21; S12 S11] into [T22 T21; T12 T11]-1. It should be inversed. Now, I wonder if this is correct?
    •   Alt27th January 2012, 04:06
      advertising
  4. #4
    Advanced Member level 2
    Points: 8,021, Level: 21
    Mazz's Avatar
    Join Date
    Nov 2001
    Posts
    676
    Points
    8,021
    Level
    21
    The argument is know in literature as S-parameter bisection.
    There are different studies about that, google it or take a look at IEEE. The problem is about the possibility to find a single solution in closed form, that is not always guaranteed.
    If you are an Agilent ADS user, there is an example at: S-Parameter Bisection Using Optimization Techniques
    The main issue with this techniques is that it works with simulated (no noise, perfect data) data, but if you use measurement data (that usually has some ripple and are not perfectly symmetrical) you can easily have glitches in the final results.
    I hope it can help.
    Mazz
    1 members found this post helpful.
  5. #5
    Points: 132, Level: 1
    Colin Warwick's Avatar
    Join Date
    Jun 2008
    USA
    Posts
    7
    Points
    132
    Level
    Quote Originally Posted by Mazz View Post
    ...If you are an Agilent ADS user, there is an example at: S-Parameter Bisection Using Optimization Techniques
    Mazz
    Thanks for the mention, Mazz! Mmrobles, please contact us if you'd like a trial license of ADS.
    •   Alt27th January 2012, 14:13
      advertising
  6. #6
    Join Date
    Jul 2010
    Posts
    19
    Points
    503
    Level
    I hope it can help.
    Mazz
    Thanks a lot for this. I'm trying to look for it at Google for days and I can't find the right keyword. So it's called "S-parameter bisection". I'm not an ADS user, but I'm trying to read the literature. I thought it was just a straightforward mathematical calculation, but seems like it is not. My measurements are real s2p files from a VNA, so I dunno if it can be split accurately?
