[SOLVED] What is the difference between BUFFER and OUT in VHDL?
iVenky
Advanced Member level 2
College Station, Texas
Hello everyone. I am new to VHDL. I want to know the difference between BUFFER and OUT because both look similar.
Thank you in advance
out: the value of an output port can only be updated within the entity model; it cannot be read.
buffer: the value of a buffer port can be read and updated within the entity model. However, it differs from the inout mode in that it cannot have more than one source and that the only kind of signal that can be connected to it can be another buffer port or a signal with at most one source.
VHDL Primer by J. Bhasker is a good book to start with.
