+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 2
    Points: 1,426, Level: 8
    Join Date
    Dec 2011
    Posts
    129
    Points
    1,426
    Level
    8
    Peak-to-Peak Voltage to dB conversion
    I have been searching for an equation to convert Peak to Peak Voltage to dB and I have found 4 slightly different equations that all claim to do the same thing:
    1) dB = 20*log_10(Vpp/0.707)
    2) dB = 20*LOG10(Volts_peak_to_peak/SQRT(0.008*Z))
    3) db = (20log10) (RMS ) & RMS= 0.707*P-P
    4) dB = 20 log10 (Voltage 1 / Voltage 2)
    Can anyone comment on a preferred method or advise on any of these equations please?
    Thanks.
    •   Alt28th December 2011, 19:58
      advertising
  2. #2
    Points: 7,067, Level: 20
    klystron's Avatar
    Join Date
    Jul 2002
    South Africa
    Posts
    1,014
    Points
    7,067
    Level
    20
    Re: Peak-to-Peak Voltage to dB conversion
    Is the signal sinusoidal ?
  3. #3
    Full Member level 2
    Join Date
    Dec 2011
    Posts
    129
    Points
    1,426
    Level
    8
    Hi klystron,
    Yes, for the purposes of this research we can consider that the input will be a Sine wave with attenuation between 0 and 10V PP (+/-5V PP).
    Thanks - hope that helps.
  4. #4
    Points: 7,916, Level: 21
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Italy
    Posts
    1,098
    Points
    7,916
    Level
    21
    dB is not a measurement unit like ,for instance, volts are. It is a ratio between two quantities of the same type.
    The last equation is correct and can be used to represent a gain or a loss, in dB. In fact if you have a voltage gain of, lat me say, 1000 means the ouptut voltage Vo will be 1000*Vi (input voltage). Using the last equation we will have GdB = 20*log10(Vo/Vi) = 20*log10(1000*Vi/Vi) = 20*log10(1000) = 60 dB. Vo and Vi must be of the same type: both peak-to-peak or RMS or peak.
    It could be you want, instead, to convert your voltage to dBV that is a logarithmic measurement unit that has a reference of 1Vrms. In this case, first of all you need to convert from peak-to-peak to RMS. In case of sinusoidal signal you just have to divide by 2*sqrt(2), then apply the dB formula using Vi = 1V:
    dBV = 20*log10[ Vpp/(2*sqrt(2) ]
    Or could also that you want to calculate the power in a logarithmic scale. In this case you also need to know the resistance (R) across which the voltage is applied. Also in this case we need the RMS voltage, that is Vrms = Vpp/(2*sqrt(2))
    The power is given by: P = (Vrms)˛/R. A logarithmic popular measurement unit for power is dBm (that means referred to 1 mW). The formula is:
    dBm = 10*log10(P/1mW) = 10*log10[(Vrms)˛/(0.001*R)] = 10*log10[(Vpp)˛/0.008*R] (is your eq. 2, using the logarithm properties)
    3 members found this post helpful.
    •   Alt28th December 2011, 22:56
      advertising
  5. #5
    Full Member level 2
    Join Date
    Dec 2011
    Posts
    129
    Points
    1,426
    Level
    8
    Quote Originally Posted by albbg View Post
    Thanks for the reply - can I ask you to clarify your working on these 3 equations please. For a Vin of 1V PP and a Vout of 1000V PP (1000x Gain), using the 3 equations you have listed, I get the following:
    20*log10(1000/1) = 20,000
    20*log10(1000*1/1) = 20,000
    20*log10(1000) = 20,000
    Sorry if I've misunderstood your reply - but I don't see how you're getting 60dB.
    Perhaps if you could also show a working for 50% attenuation?
    <edit 30/12/2011>
    I have added an edit to this post because my workings above are incorrect - the equations resolve to 60dB as albbg stated in the original post. Thanks.
    Last edited by juz_ad; 30th December 2011 at 14:29. Reason: Mistake in my working of supplied equations.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Italy
    Posts
    1,098
    Points
    7,916
    Level
    21
    Simply log10(1000) = 3 because 10^3 = 1000
    then 20*3 = 60 dB
  7. #7
    Points: 10,418, Level: 24
    Join Date
    Sep 2001
    Argentina
    Posts
    1,131
    Points
    10,418
    Level
    24
    Quote Originally Posted by juz_ad View Post
    1) Maybe there is a mistype? If you substitute Vpp/0.707 by Vpk*0.707, it is the expression of a voltage in dBV (dB realtive to 1V) assuming it is sinusoidal.
    2) where does it came from? It may be related to voltage if dBu for telephony levels (but 0.008 would need more digits)
    3) is the similar to 1) if you take Vpk instead of Vpp
    4) is the ratio V1/V2 in dB; voltages must be rms values, of also may be peak values if both have the same vaweform.
    Regards
    Z
  8. #8
    Full Member level 2
    Join Date
    Dec 2011
    Posts
    129
    Points
    1,426
    Level
    8
    From the advice I have received here and elsewhere it seems that, for my purposes (comparing the gain response of two VCA circuits) - then:
    GdB = 20log10(Vout/Vin)
    ...seems to work. Vin for both circuits is a sine from the same, known source and is considered, for the sake of comparison to be '0dB' (10V PP) - any change in gain/attenuation shows as a +/-dB change. Does this sound reasonable?
    Technically, for voltages, I *think* I should be using dBu - but I *think* for basic comparison the above equation will do.
    I could do with some help on one way to manipulate this equation. If GdB = 20log10(y / Vin) = x - where I know the value of 'x' and need to calculate the value of 'y' - e.g. GdB = 20log10(y / Vin) = 40 ?
    Thanks again for all the help - much appreciated.
    •   Alt30th December 2011, 14:40
      advertising
  9. #9
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Italy
    Posts
    1,098
    Points
    7,916
    Level
    21
    OK, 0 dB gain means the Vout = Vin.
    dBu is one of the logarithmic measurement unit used for voltages. The reference is 0.7746 Vrms
    The formula is dBu = 20*log10(V/0.7746) where V must be exspressed in rms value
    To convert back from x = 20*log10(y/Vin) ==> x/20 = log10(y/Vin) ==> 10^(x/20) = y/Vin ==> y = Vin*10^(x/20)
    By the way 10^(x/20) is the linear voltage gain.
    In you example Glin = 10^(40/20) = 100 then y = 100*Vin
