+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 6
    Points: 255, Level: 3
    Join Date
    Nov 2011
    Posts
    14
    Points
    255
    Level
    Converting battery powered baby swing to wall plug power
    There's a similar post out there about converting a battery powered baby swing to run off a dc power supply but since I'm not sure if it's cool to hijack someone's post I just started a new one.
    Here's the link to what I'm trying to do: Russelldad's blog: Guest Post: Baby Swing Batteries/Plug Switch Modification
    That link provides some text to describe how the circuit needs to be hooked up but what I really need is a picture, or some much more detailed text. I've got the parts (DC power supply, adapter plug, wire and SPDT switch) ready to go. Just need some input on what needs to connect to what.
    The swing is powered by 4 D batteries and I'd like be able to operate from either wall power or battery power depending on which way the switch is thrown. Throw the switch one way and the swing should run off the batteries - throw it the other way and the swing should run off the wall plug power. I'm hoping I got the right switch as I'm seeing websites out there that make me think I should have gotten a DPDT switch.
    Can anyone take a look at this pic and tell me which letters need to be connected?
    Thanks
    •   Alt22nd December 2011, 01:57
      advertising
  2. #2
    Super Moderator
    Points: 46,819, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,675
    Points
    46,819
    Level
    52
    Re: Converting battery powered baby swing to wall plug power
    From the description you won't need to do anything to the existing internal on/off switch. It shouldn't make a difference whether it goes to bat+ , or to bat-.
    Is the center pin B of your switch really the common pin? (I'll assume it is.)
    Disconnect red wire at BAT+ PIN D. Connect this red wire to SWITCH PIN B.
    Wire BAT+ PIN D to SWITCH PIN A.
    Wire plug+ PIN G to SWITCH PIN C.
    Wire plug- PIN F to BAT- PIN E (common ground).
    •   Alt22nd December 2011, 07:26
      advertising
  3. #3
    Points: 17,009, Level: 31
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    This way...........
    Click image for larger version.
    ---> Hike with wise men , then you will be wise <---
    •   Alt22nd December 2011, 08:13
      advertising
  4. #4
    Advanced Member level 5
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    But note one important thing. The batteries supply Constant and pure DC, while the plug pack will have unregulated DC with ripples. This may damage your circuits which are now running safe with batteries. Measure the voltage with and without load, and both should be almost the same. Coz i have modified a similar circuit where i have used LM317 based regulator.
    Cheers
