matrixofdynamism
Advanced Member level 2
The voltage drop in the resistors seems to be varying depending on the power supply and the other impedances in the circuit. But the one across he diode seems to be constant. A 10 ohm resistor can have a varying voltage drop across it but a zenner diode always has the same voltage drop across it always, HOW?
Also, in the reverse breakdown according to the graph an infinite amount of current shall flow through the diode right? This means that the diode shall be destroyed. But no such breakdown and huge current flows in the resistor.
I just need answers in terms of the internal working of the diode vs resistor. Thanks .
