+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 1
    Points: 887, Level: 6
    Join Date
    Dec 2011
    Posts
    38
    Points
    887
    Level
    [Moved] MikroC Pro for 74HC595 on a PIC16F887
    I have spent 3 days trying to find and understand code to turn simply turn on some LED's through the 74HC595, so figured must be time to ask and see if anyone can help.
    Have read the manuals and tried many examples from Mikro and posts.
    I can write for Arduino but cannot get a handle on what is happening with 'C'. Have tried the Mikro Soft SPI and could not get it to work.
    If anyone can write a few lines so that I can understand how the data is transferred to turn on the LED's that would be greatly appreciated.
    There are 8 LEDS attached to the 74HC595.
    Would like to turn on/off individual LEDs using binary eg 0b00110011
    This is the start of my code.
    Code C - [expand]
    8
    9
    10
    11
    #define CLOCK1 PORTD.F0;                 // RD0 -----> Pin 11 Clock
    #define LATCH1 PORTD.F1;                 // RD1 -----> Pin 12 Latch
    #define DATA1 PORTD.F2;                  // RD2 ------> Pin 14 Data
    void main() {
      TRISD.F0 = TRISD.F1 = TRISD.F2 = 0;                // Pins set to output
         // send 0b00110011 to 74HC595
         // clock?
         // latch low to receive data
         // latch high for 74HC595 to turn on LEDs
    Thanks in advance.
    Robert
  2. #2
    Advanced Member level 3
    Points: 4,828, Level: 16
    papunblg's Avatar
    Join Date
    Oct 2010
    Kolkata India
    Posts
    726
    Points
    4,828
    Level
    16
    Blog Entries
    9
    Re: MikroC Pro for 74HC595 on a PIC16F887
    For idea see the following link for code and schematic for PIC16F84A:--
    See: Extend OUTPUT pins of a PIC micror with the help of output shift register 74HC595
    http://www.edaboard.com/thread231411.html
    Rajsekhar Nag
    Knowledge Grows When Shared
    1 members found this post helpful.
    •   Alt21st December 2011, 19:04
      advertising
  3. #3
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    Re: [Moved] MikroC Pro for 74HC595 on a PIC16F887
    Here is a recent thread discussion concerning several different varieties of shift registers, including 74HC595, and interfacing to PIC.
    Questions bout shiftregisters (74HC575, 74HC597)
    BigDog
    •   Alt21st December 2011, 20:00
      advertising
  4. #4
    Member level 4
    Points: 2,415, Level: 11
    Join Date
    Nov 2005
    Montenegro
    Posts
    74
    Points
    2,415
    Level
    11
    Here is routines for sending data to hc595:
    #define SHIFT_DATA     PORTB.F0         // 74HC595 Data
    #define SHIFT_LATCH    PORTB.F1         // 74HC595 Latch
    #define SHIFT_CLOCK    PORTB.F2         // 74HC595 Clock
    void latch_595() {
       SHIFT_LATCH = 1;
       asm nop;
       SHIFT_LATCH = 0;
    void shift_out_HC595(char one_digit) {
       char x;
       for (x=0; x<=7; ++x) {
          if (one_digit & 0x80) SHIFT_DATA = 1;
          else SHIFT_DATA = 0;
          one_digit <<= 1;
          SHIFT_CLOCK = 1;
          asm nop;
          SHIFT_CLOCK = 0;
  5. #5
    Member level 1
    Join Date
    Dec 2011
    Posts
    38
    Points
    887
    Level
    Thanks All, lots to work through here.
    Deniah. Tried the code but still no LEDs turning on.
    In the shift_out_HC595, should '++x' be 'x++' or does it not matter?
    My code for main -
    void main() {
    TRISB = 0; // PortB pins to output
    ansel = anselh = 0; // All pins to digital
    one_digit = 0b00110011;
    SHIFT_LATCH = 0; // latch low to enable data to HC595
    shift_out_HC595;
    latch_595;
    •   Alt23rd December 2011, 11:16
      advertising
  6. #6
    Member level 4
    Join Date
    Nov 2005
    Montenegro
    Posts
    74
    Points
    2,415
    Level
    11
    Write this in main:
    void main() {
       TRISB = 0;                    // set PORTB to be output
       ANSEL  = 0;                  // configure AN pins as digital I/O
       ANSELH = 0;
       shift_out_HC595(0b00110011);
       latch_595();
       while (1) {
  7. #7
    Member level 1
    Join Date
    Dec 2011
    Posts
    38
    Points
    887
    Level
    Thanks Deniah. Yes ..... it works !!!!!
    Interestingly -
    The LED's light up opposite to the output, that is, the pin that gets a 1 turns off (if I understand the start of the loop correctly)
    The last LED did not light up at all until I shifted the while(1) statement to the top of the main(). Then they all worked fine - Still have not worked out how that made a difference.
    Just two further questions please.
    What does the code "one_digit <<=0" do?
    In the code if (one_digit & 0x80) - is the 0x80 the memory address where the byte is stored for sending to the HC595?
    Thanks again.
  8. #8
    Member level 4
    Join Date
    Nov 2005
    Montenegro
    Posts
    74
    Points
    2,415
    Level
    11
    If you move while(1) statement above calls to shift_out_hc595() and latch_595(), then these two functions will newer execute.
    << and & are bitwise operators.
    << operator moves bits to the left, and
    & is bitwise AND operator. It returns 1 if both bits are 1, otherwise returns 0.
    Compile you program and run debugger. From variable list select variable to watch, change value representation to binary and step thru the code to see what is happening.
  9. #9
    Full Member level 4
    Points: 1,492, Level: 8
    Join Date
    Dec 2011
    Posts
    198
    Points
    1,492
    Level
    8
    In the above code, what should be inside the
    While(1)
    •   Alt15th February 2012, 08:17
      advertising
  10. #10
    Member level 1
    Join Date
    Dec 2011
    Posts
    38
    Points
    887
    Level
    Quote Originally Posted by Rohith_elec View Post
    While(1)
    I got a message saying this thread has been deleted so I don't know if you will receive this message.
    If so, I changed to using Arduino code as the MicroC was to difficult for me.
    All the best,
    Robert
  11. #11
    Full Member level 4
    Join Date
    Dec 2011
    Posts
    198
    Points
    1,492
    Level
    8
    Quote Originally Posted by Robert T View Post
    Robert
    No, its not deleted, its only moved,
    BTW u got it working on mikroC,
    while()
  12. #12
    Member level 1
    Join Date
    Dec 2011
    Posts
    38
    Points
    887
    Level
    while()
    I used the SPI routine in MicroC after much study it was fairly simple.
    void main() {
    ansel = anselh = 0;
    SPI_Init();
    While(1) {
    SPI1_Write(0b00000001);
    delay_ms(1000);
    SPI1_Write(0b00000000);
    delay_ms(1000);
    Hope this is helpful.
    Robert
