+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 1
    Points: 605, Level: 5
    Join Date
    Dec 2011
    Rajkot,India
    Posts
    16
    Points
    605
    Level
    Servo motor VS-2 control
    I am interfacing VS-2 servo with ATMEGA32 controller. I want to know how can we know PWM and rotation angle relation of servo motor specially for VS-2 servo
    •   Alt18th December 2011, 11:45
      advertising
  2. #2
    Points: 17,009, Level: 31
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    ---> Hike with wise men , then you will be wise <---
    •   Alt18th December 2011, 13:00
      advertising
  3. #3
    Join Date
    Dec 2011
    Rajkot,India
    Posts
    16
    Points
    605
    Level
    Re: Servo motor VS-2 control
    I have generated simple PWM signals by following program.But still there is some problem.motor is moving 20 degree whatever pulse we are giving.
    #include<avr/io.h>
    #include<compat/deprecated.h>
    #include<util/delay.h>
    main()
       sbi(DDRD,5);
       while(1)
         sbi(PORTD,5);
         _delay_ms(0.6);
         cbi(PORTD,5);
         _delay_ms(19.4);
         _delay_ms(2000);
         sbi(PORTD,5);
         _delay_ms(1.5);
         cbi(PORTD,5);
         _delay_ms(18.5);
         _delay_ms(2000);
         sbi(PORTD,5);
         _delay_ms(2.4);
         cbi(PORTD,5);
         _delay_ms(17.6);
         _delay_ms(2000);
    •   Alt28th December 2011, 07:09
      advertising
  4. #4
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    Quote Originally Posted by Jayk View Post
    The issue you are dealing with is the lack of a loop around each different pulse width:
    Try something like this:
    #include<avr/io.h>
    main()
       sbi(DDRD,5);
      while(1)
         int i;
         for(i=10000; i > 0; i--)
             sbi(PORTD,5);
             _delay_ms(0.6);
             cbi(PORTD,5);
             _delay_ms(19.4);
             sbi(PORTD,5);
             _delay_ms(1.5);
             cbi(PORTD,5);
             _delay_ms(18.5);
             sbi(PORTD,5);
             _delay_ms(2.4);
             cbi(PORTD,5);
             _delay_ms(17.6);
    You must constantly generate the PWM of a particular duty cycle and frequency to maintain the rotor in that particular position. Otherwise you are generating an average of all three PWM widths.
    BigDog
  5. #5
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    The control signal is a digital PWM signal with a 50 Hz frame rate.
    Within each 20 ms timeframe, an active-high digital pulse controls the position.
    The pulse nominally ranges from 1.0 ms to 2.0 ms with 1.5 ms always being center of range.
    Pulse widths outside this range can be used for "overtravel" -moving the servo beyond its normal range.
    This PWM signal is sometimes (incorrectly) called Pulse Position Modulation (PPM).
    The servo is controlled by three wires: ground, power, and control.
    The servo will move based on the pulses sent over the control wire,
    which set the angle of the actuator arm.
    The servo expects a pulse every 20 ms in order
    to gain correct information about the angle.
    The width of the servo pulse dictates the range of the servo's angular motion.
  6. #6
    Join Date
    Dec 2011
    Rajkot,India
    Posts
    16
    Points
    605
    Level
    Quote Originally Posted by kak111 View Post
    Sir i have tried out every pulse between 1ms to 2ms and given at every 20ms but still cant control the servo motor angle.Motor is rotating whole 180 degree.
    •   Alt29th December 2011, 12:05
      advertising
  7. #7
    Newbie level 1
    Points: 177, Level: 2
    Join Date
    Dec 2011
    Posts
    Points
    177
    Level
    I have tried the above program given by bigdogguru with VS-2 interfaced with ATmega32 but there is continuous rotation of motor from 0° to 180° immaterial of the variation in the duty cycle... moreover once the motor rotates clockwise, it doesnt move counter clockwise.. Nw wat should do ??
