"setenv" command not found on my redhat how i will get the command?
mit ngr
Newbie level 3
hello
i want to istall system c on my redhat 5 i can't do it because error setenv command not found in my terminal
how i got access of setenv command
Welcome here, mit ngr! :)
But you really should learn to use Google some time:
KMLM List - Accellera Systems Initiative
That took all of 2 minutes, but that's 2 minutes YOU should have put in BEFORE wasting other people's time by asking question on a forum that 2 minutes of Googling might have answered. :evil: (btw this forum is searchable too)
To make up for it: please report back whether the tips above solve the issue or not?
i have solved problem bt facing problem in configure command
error
[root@localhost objdir]# sh ../configure --prefix=/home/student/systemc-2.2.0
^[[5~checking build system type... configure: error: cannot guess build type; you must specify one
mitul s. nagar
error
mitul s. nagar
How did you solve the problem of "setenv"? I am getting same error, Could you please help me?
setenv is a shell command, only in certain shells. The
C shell is Cadence's general assumption; what is yours?
