mehul patel
Newbie level 1
Hello
I have c code which collect the GPS data using XAG-49 micro-controller but it gives some garbage values after $GPRMC string. It shows till last 'W' and than send me some garbage values. Can any one tell me what is the problem in my code?
#include <REGXAG49.H> // call the library function for the microcontroler to define the register
void function(); //function declaration
void uart_init(); //function declaration
void uart_sendbyte(unsigned char *messageOne); //function declaration
void uart_send(unsigned char ch); //function declaration
int uart_readbyte(); //function declaration
int uart_read(); //function declaration
unsigned char mess[80]; // global variable
const char CR = 0x0D; //carriage return
const char LF = 0x0A; // line feed (New line)
const char BB = 0x22; // symbol "
const char CTRZ= 0x1A; // control Z
sbit P10=P1^0; //RTS signal
unsigned char buffer1[70]; // global variable
unsigned char position[70]; // global variable
unsigned char gpsdata[70]; // global variable
void gpscatch(); //function declaration
void uart1_init(); //function declaration
int readbyte();
int read();
int gpsfilter();
void function() // Modem function start
uart_sendbyte("AT~"); // send string AT
uart_send(CR); //carriage return
uart_send(LF); // line feed (New line)
uart_readbyte(); // read modem answer (response)
uart_sendbyte("AT+CMGF=1~"); // send string AT+CMGF=1 (set modem in text mode)
uart_sendbyte("AT+CMGS=~"); // send string AT+CMGS( for send message)
uart_send(BB); //send symbol "
uart_sendbyte("+447412067332~"); // send phone number +447412067332
uart_send(BB); // send symbol "
uart_sendbyte(gpsdata); // send message buffer
uart_send(CTRZ); // send to the modem control Z
void uart_init() // baud rate function
SCON = 0x53; // serial register read and write
TMOD = 0x20; // timer 1 in mode 2
RTL1 = 238; // transmit speed 9600 bps
TR1 = 1; // start timer 1
void uart_sendbyte(unsigned char *messageOne) // send stirng function
int i=0; // local variable declaration
while(messageOne!='~') // compare the value of the buffer to '~'
uart_send(messageOne); // call send function
i++; // increase the value of the buffer
void uart_send(unsigned char ch) // uart send function
S0BUF = ch; // send character
while(!TI0); // wait until the flag bit TI0 is set
TI0=0; // clear the flag
int uart_readbyte() // uart store modem answer
unsigned int buffer[30]; // buffer for the answer
signed int b=-1; // local variable declaration
do{ // loop do
b++; // increase local variable
buffer=uart_read(); // call uart read function and store answer
if(buffer==62) // control the buffer value >
return 0;
break;
} // end if
}while(buffer!=10); // control the buffer value LF
return 0; // end function
int uart_read() // uart read function
int k=1; // local varibale declaration
while(!RI0); // wait till the RI0 bit is set
RI0=0; // clear the flag bit RI0
k=S0BUF; // read out the receive buffer
return k; // return the buffer value
void gpscatch() //start GPS catch function
uart1_init(); //define transfer speed
readbyte(); //call function readbyte
void uart1_init()
S1CON = 0x53; //define serial mode 1
T2MOD = 0x30; // Timer 2 define as 16 bit timer
T2CAPH = 0xFF; //value for the Higherbyte FF
T2CAPL = 0xDC; // value for lowbyte DC transfer speed 4800 bps
TR2 = 1; // start timer 2
int readbyte() //start readbyte function
signed int b=-1, j=0, m,a=0; //local variable declaration
for(m=0; m<=70;m++)
buffer1[m]=0;
position[m]=0;
do{
b++;
buffer1=read();
if((buffer1[b-2]=='R') && (buffer1[b-1]=='M') && (buffer1=='C'))
position[j]=buffer1[b-5];
position[j+1]=buffer1[b-4];
position[j+2]=buffer1[b-3];
position[j+3]=buffer1[b-2];
position[j+4]=buffer1[b-1];
position[j+5]=buffer1;
for(j=6; j<68; j++)
position[j]=read();
P2=position[j];
if(position[j]=='E')
a++;
if(a==1)
j=0;
return 0;
}while(1);
return 0;
int read()
int k=1;
while(!RI1);
RI1=0;
k=S1BUF;
return k;
int gpsfilter()
int z=0, x=0, i,a=0;
P10=0;
for(i=0; i<70; i++)
gpsdata=0;
while(1)
while((position[x-4]=='$')&&(position[x-1]=='R')&&(position[x]=='M'))
gpsdata[z]=position[x-4];
gpsdata[z+1]=position[x-3];
gpsdata[z+2]=position[x-2];
gpsdata[z+3]=position[x-1];
for(z=4;z<=70;z++)
gpsdata[z]=position[x];
if(position[x]=='E')
a++;
if(a==1)
gpsdata[68]='0';
gpsdata[69]='0';
gpsdata[70]='\0';
return 0;
x++;
x++;
return 0;
void main () // the execution function ( main function) no return value cause (void)
WDCON = 0; // watchdog off
WFEED1 = 0xA5;
WFEED2 = 0x5A;
gpscatch();
gpsfilter();
uart_init();
while(1)
function();
int readbyte();
int read();
int gpsfilter();
do{ // loop do
return 0;
break;
} // end if
void uart1_init()
for(m=0; m<=70;m++)
buffer1[m]=0;
position[m]=0;
do{
b++;
buffer1=read();
for(j=6; j<68; j++)
position[j]=read();
P2=position[j];
a++;
if(a==1)
j=0;
return 0;
}while(1);
return 0;
int read()
int k=1;
while(!RI1);
RI1=0;
k=S1BUF;
return k;
int gpsfilter()
P10=0;
for(i=0; i<70; i++)
gpsdata=0;
while(1)
for(z=4;z<=70;z++)
a++;
if(a==1)
gpsdata[68]='0';
gpsdata[69]='0';
gpsdata[70]='\0';
return 0;
x++;
x++;
return 0;
WFEED1 = 0xA5;
WFEED2 = 0x5A;
gpscatch();
gpsfilter();
uart_init();
while(1)
function();
