CID (Contact ID) Connection integration on transmitter
kleintoren
Newbie level 3
Colesberg, South Africa
Hi
I am reasonably new to electronics but have been able to design and build a few complex projects and learning fast.
I have recently designed and built a 15W RF FSK transmitter for alarm transmission with 9 programmable contacts. I would like to get advice on integrating CID interface (Alarm Panel in Ademco Contact ID Format => Transmitter) into the transmitter.
I could implement reading/transmitting via separate chips dtmf or using using current AVR, PIC chip to handle coms. Have also dabbled with ARM chips but seem to be overkill for the application.
I am also looking for more info on EOL (End of line resistor/Tamper) Monitoring via chip - have been using resistive bridge and Wheatstone bridge but application seams limited (except if i'm missing something)
do you have any inoframtion about Contact ID ademco?
