Optimal solution for isolating faulty IC
Delta11
Junior Member level 3
I am dealing with a circuit that is showing short circuit between power and ground lines. And I am fairly sure that some IC is faulty or has shorted out causing this short circuit. I know that by removing each IC individually I can ultimate isolate the faulty IC but the process is not an optimal solution. Anybody has ideas on a better solution? Feel free to suggest or exchange ideas.
Thx.
