+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Junior Member level 3
    Points: 935, Level: 6
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    50 ohm matching question
    Neewbie....
    What is the proper way to connect/match components in an RF front end assuming all have 50 ohm IO? Microstrip traces? LC matching networks, no matching required?
    Thanks
    Rich
  2. #2
    Advanced Member level 2
    Points: 6,074, Level: 18
    Join Date
    Jan 2007
    Sweden
    Posts
    603
    Points
    6,074
    Level
    18
    Re: 50 ohm matching question
    Which method to select depend on your application, components cost money, traces cost PCB space. If matching is needed depend on your requirements. If no matching results in good enough matching is further matching improvement above specification, which you not get paid for.
    1 members found this post helpful.
  3. #3
    Points: 5,735, Level: 17
    Join Date
    Mar 2002
    Posts
    509
    Points
    5,735
    Level
    17
    Quote Originally Posted by richas View Post
    Neewbie....
    Thanks
    Rich
    It depends. If you are at 88MHz, you will not want to try to use MicroStrips. If you
    are at 14GHz you will not want to use L's,C's, R's unless they are like 0201 size....
    You have to know what is the Impedance of one component them match it to the
    next. You should read a book a good, cheap, and easy to understand book is
    "RF Circuit Design" By Bowick. You can also Google RF Matching.
    RF Match
    In the photo the Red Dot is the Components Impedance and every time the white line
    changes direction that is due to a new Element/Matching Component.
    •   Alt7th December 2011, 22:41
      advertising
  4. #4
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    Quote Originally Posted by Element_115 View Post
    RF Match
    I am at 1GHz. I am putting together an RF front end, LNA and SAW, to a receiver IC. The antenna, LNA, and SAW filter all have 50 ohm IO so perhaps I do not need matching. I looking into connecting the components with microstrip, according to a online calculator the trace should be 140 mil thick...........
    Rich
    •   Alt8th December 2011, 00:59
      advertising
  5. #5
    Member level 2
    Points: 453, Level: 4
    Join Date
    Oct 2011
    Posts
    44
    Points
    453
    Level
    Copper thickness is usually 1/2oz(0.7mil) or 1oz(1.4mil). What substrate are you using?
    •   Alt8th December 2011, 19:12
      advertising
  6. #6
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    Quote Originally Posted by Microwave123 View Post
    I am using 1oz Cu and FR-4 0.062"
    Thanks
    Rich
  7. #7
    Member level 2
    Join Date
    Oct 2011
    Posts
    44
    Points
    453
    Level
    the material and thickness you are using is standard for non-RF circuits. For the frequency you are operating at, you should consider using Rogers material. At 1 GHz, the Rogers 4003 is decent. At even higher frequency, above 6GHz or so, you should start using Alumina or Quartz.
  8. #8
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    The high frequency portion is small, SMA, lna, saw, and then directly into rx ic. Perhaps fr4 would suffice?
  9. #9
    Member level 2
    Join Date
    Oct 2011
    Posts
    44
    Points
    453
    Level
    I don't think FR 4 would suffice for microwave application. At microwave frequency, the dielectric constant variance is high ranging from 3.9-4.5, this is a guess. Also, the loss tangent is quite high, on the order of 0.035. Rogers material has low dielectric constant variance and lower loss tangent.
  10. #10
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    OK, good to know, thank you very much for your help. I will recalculate the microstrip with Rogers 4003.
    Rich
    •   Alt8th December 2011, 21:08
      advertising
  11. #11
    Join Date
    Mar 2002
    Posts
    509
    Points
    5,735
    Level
    17
    Rich
    1GHz is low enough to use discrete components (0603).
    Now, even though all your parts are 50 ohms you still should put some "Hooks" in
    your layout for unforeseen issues.
    Between every device Antn,SAW, & LNA. you should put pads for a series and shunt
    component (an "L-Matching Network". If everything is perfect (Simulation ≡ Design)
    then you will just need to put a 0 ohm resistor in the Series and everything is great.
    But if the Simulation and the Physical design don't match you can tune up the design.
  12. #12
    volker_muehlhaus
    It really depends what line length you need.
    For 0.5mm FR4 thickness, the 50 ohm line width is 1mm and the insertion loss is ~0.05dB per 10mm line length.
  13. #13
    Join Date
    Jul 2011
    Posts
    25
    Points
    935
    Level
    That is really a good idea. It is always best to have options.
    Thanks to all for the advice.
