+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Newbie level 6
    Points: 262, Level: 3
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    pulse amplitude modulation
    dear friends
    plz i need a usufull and simple design to the circuit (pulse amplitude modulation) and i hope if anybody help me to simulate it in orcad
    appreciate your works
    thanks a lot regards
    •   Alt1st December 2011, 00:47
      advertising
  2. #2
    Advanced Member level 2
    Points: 6,774, Level: 19
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    Re: pulse amplitude modulation
    Setup a PAM Circuit with CD4016
    ---------- Post added at 08:25 ---------- Previous post was at 08:22 ----------
    http://www.doctronics.co.uk/4016.htm
    "In the middle of difficulty lies opportunity." -Albert Einstein
  3. #3
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    my friend could you please give me a circuit diagram without IC's . i mean with components ( op Amp - R-L-C......)
    thanks a lot
  4. #4
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    Quote Originally Posted by fidomido View Post
    thanks a lot
    Example circuit
    h**p://www.sta-tn.com/IJ_STA/Papers/IJSTA_V3N2_dec_2009/P8_IJSTA_V3N2_09.pdf
    PAM with CD4016 Simulation in Proteus ..
    ---------- Post added at 15:35 ---------- Previous post was at 15:22 ----------
    another Example
    h**p://cc.ee.ntu.edu.tw/~wujsh/PC%20Chapter3.ppt
    ---------- Post added at 16:04 ---------- Previous post was at 15:35 ----------
    More examples with JFET
    h**p://ptuece.loremate.com/acs/node/9
  5. #5
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    please can you make the simulation with RC or JFET wit the values
  6. #6
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    JFET based PAM Circuit
    JFET-BFW10
    Resistor -100k
    Signal-100Hz 5vpp,Sine ,control -1000Hz -5Vp Pulse
    •   Alt2nd December 2011, 18:37
      advertising
  7. #7
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    i use this design and i don't know what is the resoan
    please check it and tell me the where is the problem ?
    thanks
    ---------- Post added at 19:08 ---------- Previous post was at 18:57 ----------
    my advisor want the sample and hold circuit by using op-amp and JFET
  8. #8
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    can you make a simulation or just give the values for these components
    regards
    Click image for larger version.
  9. #9
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    JFET Based circuits
    h**p://www-personal.engin.umd.umich.edu/~fmeral/ELECTRONICS%20II/09%25c3-FET%20Project/JFET_Project.pdf
  10. #10
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    when i want to add pulse generator in ORCAD . there are many inputs i don't know what is the meaning of them whice are : V1-V2-TD-TR-TF_PW and PER ?
    so could you please give me a random valuse to these inputs
    regards
  11. #11
    blooz's Avatar
    Join Date
    Dec 2010
    India
    Posts
    561
    Points
    6,774
    Level
    19
    Blog Entries
    regards
    V1 Starting voltage for pulse
    V2 Second voltage for pulse
    TD Time delay. Voltage will remain at V1 until this specified time.
    TR Rise time. Time required to reach V2 from V1 (Rise time must not equal to zero).
    TF Fall time. Time required for voltage to change from V2 to V1 (Again, fall
    time must not be equal to zero).
    PW Pulse width. Amount of time pulse remains at V2.
    PER Period of pulse. How often pulse actually repeats itself
  12. #12
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    could u plz give me the vaules of this design cuz my advisor want the PAM design by using sample ana hold ( and this design )
    waiting ur response
    regards
    •   Alt9th December 2011, 11:22
      advertising
  13. #13
    Newbie level 6
    Join Date
    Dec 2011
    Posts
    13
    Points
    262
    Level
    nothing works with me
    plz another examples and easy to build it !!!
    ---------- Post added at 03:54 ---------- Previous post was at 03:28 ----------
