+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Proteus -16f877a lm016l
    HOW TO configure lm016l in Proteus using16f877A
  2. #2
    Points: 8,160, Level: 21
    Easyrider83's Avatar
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,464
    Points
    8,160
    Level
    21
    Re: Proteus -16f877a lm016l
    model lm016l not need any configuration to start work. Only initialization.
    •   Alt22nd November 2011, 09:46
      advertising
  3. #3
    Newbie level 5
    Points: 243, Level: 2
    Join Date
    Nov 2011
    Posts
    8
    Points
    243
    Level
    Thanks, but how to convert hex value to ascii value ,so that i can display it in lcd
  4. #4
    Advanced Member level 5
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    You need an ASCII converter, use a site like PicList which have loads of routines, or write you own ..
    This is all you need for the lcd - the program and oscillator are specified as shown.
    •   Alt22nd November 2011, 10:16
      advertising
  5. #5
    Newbie level 5
    Join Date
    Nov 2011
    Posts
    8
    Points
    243
    Level
    Sir
    but i dont want c code,instead i need hex code to execute
  6. #6
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Quote Originally Posted by arungokul1990@gmail.com View Post
    Sir
    Sorry I do not understand, everything I have metioned relates to Pic Assembler
    Piclist assembler ascii modules - PIC Microcontoller Radix Math Methods
  7. #7
    Newbie level 5
    Join Date
    Nov 2011
    Posts
    8
    Points
    243
    Level
    Sir,
    i can't use c code, ".asm" code is to be used
  8. #8
    Junior Member level 3
    Points: 1,333, Level: 8
    Join Date
    Nov 2006
    Posts
    27
    Points
    1,333
    Level
    8
    Hi Arungokul,
    i guess i can understand your question. but let me confirm, you are trying to display Hex value of '0x5A' in the LCD dispaly [through ASCII Character]?
    If yes, well the following steps might help you [we will take example 0x5A to be displayed in LCD]
    - seperate '5' and 'A' from the HEX as 0x05 and 0x0A,
    - add 0x30 to 0x05, to result 0x35 [ASCII value of '5'] and send it to LCD
    - add 0x37 ot 0x0A, to result 0x41 [ASCII value of 'A'] and send it to LCD.
    Well you have to implement this logic in the Assembly or C.
    Hope this helped you, Better luck
    •   Alt22nd November 2011, 11:25
      advertising
  9. #9
    Newbie level 5
    Join Date
    Nov 2011
    Posts
    8
    Points
    243
    Level
    sir,
    similarly i have to display many 2 bit number on lcd,if you could give the asm code it will be helpful to me
