+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 3
    Points: 656, Level: 5
    Join Date
    Feb 2011
    CHANDIGARH
    Posts
    29
    Points
    656
    Level
    how to connect p89v51rd2(8051) having ir receiver at input and uln2803 at output
    hi all,
    how can i connect the output of IR Receiver to input of p89v51rd2 microcontroller and output of microcontroller to drive a uln2803.if i connect output of ir receiver(4.94v)directly to my microcontroller pin,will my microcontroller work?
    and one more thing,can i connect microcontroller output directly to uln2803
    @- NAVNEET
    •   Alt6th November 2011, 19:57
      advertising
  2. #2
    Join Date
    Feb 2011
    CHANDIGARH
    Posts
    29
    Points
    656
    Level
    Re: how to connect p89v51rd2(8051) having ir receiver at input and uln2803 at output
    please,anyone help me in this issue..
    @- NAVNEET
  3. #3
    Member level 1
    Points: 413, Level: 4
    Join Date
    Nov 2011
    Posts
    34
    Points
    413
    Level
    You may check if they have the same speed (bit rate) and same logic level voltage. I am not familiar with IR transceivers, refer to its datasheet.
  4. #4
    Advanced Member level 3
    Points: 6,240, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    India
    Posts
    846
    Points
    6,240
    Level
    18
    The microcontroller you are using works at 5V so you can use the 4.94V input to the microcontroller directly.
    You wish to read this, therefore the pin on which you connect this input has to be configured as input pin by writing a HIGH (or 1) to that port pin. By the way what port you are using !! and what pin !!
    Yes you can connect the microcontroller output directly to ULN 2803. The port pin you are using for this purpose is to be configured as an output by writing a LOW (or 0) to this pin.
    •   Alt7th November 2011, 13:47
      advertising
  5. #5
    Join Date
    Feb 2011
    CHANDIGARH
    Posts
    29
    Points
    656
    Level
    i am connecting my ir receiver output at P3^0 and output from P2^0 to uln 2803...so whenever my ir receiver will detect some thing,,it will give output as 1 to microcontroller
    and microcontroller will give output as 1 to drive uln2803
    can u give some idea how to write c program for this
    @- NAVNEET
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    India
    Posts
    846
    Points
    6,240
    Level
    18
    I can provide you logic and if needed, parts of program in Assembly.
  7. #7
    Join Date
    Feb 2011
    CHANDIGARH
    Posts
    29
    Points
    656
    Level
    that will be very nice of you....i will write c program from assembly
    @- NAVNEET
  8. #8
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    India
    Posts
    846
    Points
    6,240
    Level
    18
    Here is short piece of code doing what is under discussion.
    You can use the logic and modify the code to serve your purpose.
    ORG 00
    AGAIN: SETB P3.0
    CLR P2.0
    CHECK: JNB P3.0 CHECK ; KEEP POLLING P3.0
    SETB P2.0 ; ACTIVATE OUTPUT
    CALL DELAY ; WAIT TILL YOU NEED
    ; THE ALARM OR WHATEVER
    SJMP AGAIN
    DELAY: ;DELAY SUBROUTINE HERE
    RET
    •   Alt9th November 2011, 17:49
      advertising
  9. #9
    Member level 2
    Points: 431, Level: 4
    Join Date
    Aug 2011
    Mumbai
    Posts
    46
    Points
    431
    Level
    Quote Originally Posted by navneet sngh View Post
    Your application seems to be very simple.I can send u the complete C code..just upload your circuit diagram and give in your exact requirements
