prash.garg
Newbie level 3
Simulation not validating desired resonances - monopole antenna
I am trying to validate the S-parameters of a fork-monopole antenna given in the paper:
Antenna resonances required at: 2.4 GHz, 3.7 GHz, 5.25 GHz
However, I get only 2. I have used HFSS v12 for the simulation.
When I simulate without the L-shaped parasitic structure on the rear side [here only 2 resonances are expected]: the last (~5 Ghz) resonance is weak, and the first (2.4 GHz) resonance dominates.
However, on adding the L-shaped parasitic structures to the rear side [full structure], the ~5 GHz resonance vanishes & I only get the middle (~3.5 GHz) and the initial (~2.4 GHz) one:
Both solution frequencies of 7 GHz and 10 GHz give nearly same S-11 plots.
I have used a rectangular T-structure instead of the slightly smoother one, as suggested in the paper.
Kindly help...I have been trying this over a month now and am unsuccessful.
Thanks in advance.
Attachment: my 2 simulation files and plots.
Thanks in advance.
