+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Member level 2
    Points: 1,636, Level: 9
    Achievements:
    7 years registered
    thudpucker's Avatar
    Join Date
    Feb 2007
    North Alabama
    Posts
    50
    Points
    1,636
    Level
    9
    Wireless Earphones for a PC.
    You guys are all way over my head in this stuff.
    I once had a Wireless head set for the TV. I think it was Infra-red.
    It was a pain thought.
    I wonder now, if there is such a thing as Wireless Headset for the PC?
    I have a Dell Inspironone. with the small .3 mm Stereo plug.
    I'm curious because I'm up so late and the wife is sleeping and I like my music while I work.
    Dick
    •   Alt2nd November 2011, 05:16
      advertising
  2. #2
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,805
    Level
    52
    Re: Wireless Earphones for a PC.
    My wireless headphones are Acoustic Research AW721C.
    The base unit sends out a cable terminating with a 1/8 inch stereo phone plug. This will work with a typical computer.
    An adapter cable was included, terminating in two phono plugs.
    2 members found this post helpful.
  3. #3
    Member level 2
    Achievements:
    7 years registered
    thudpucker's Avatar
    Join Date
    Feb 2007
    North Alabama
    Posts
    50
    Points
    1,636
    Level
    9
    If I have this correct, your base unit is connected to the PC through the cable with the small stereo plug.
    Then the Base unit broadcasts to the Head set through the air. Not through a Cable?
    Can you walk around the room with the headsets on and still hear the music from the PC?
  4. #4
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,670
    Points
    46,805
    Level
    52
    Quote Originally Posted by thudpucker View Post
    Yes, it works by radio transmission not infrared. I can walk four rooms away and still get sound in the headphones.
    The sound is stereo. Bass is strong. Sound quality compares to wired headphones.
    The headphones use two AAA rechargeable batteries. They recharge when you set the headphones on the base unit.
    The base unit is powered by a 9V wall wart.
    Drawbacks are few. There are occasional brief moments of static.
    The original sound from the computer/tv/receiver cannot be too soft, since it is not amplified very much by either the base unit nor the headphones.
    1 members found this post helpful.
  5. #5
    Newbie level 1
    Points: 52, Level: 1
    Join Date
    Sep 2012
    Posts
    Points
    52
    Level
    Found this lens on Cheap Headsets :)
  6. #6
    Member level 2
    Achievements:
    7 years registered
    thudpucker's Avatar
    Join Date
    Feb 2007
    North Alabama
    Posts
    50
    Points
    1,636
    Level
    9
    Quote Originally Posted by HappySnappy View Post
    Thanks Happy.
    I'm still stuck with the time changes and visitors and my sleep cycles.
    Maybe I'll get the Grossly normal folks who want to sleep at night, to chip in for a good headset.
    I sure thank you guys for keeping me in mind. My health died and I'm not nearly so active as I 'wunct wuz'
    •   Alt7th September 2012, 00:00
      advertising
  7. #7
    Junior Member level 1
    Points: 115, Level: 1
    Join Date
    Aug 2012
    Posts
    15
    Points
    115
    Level
    I heard about wireless headphone but I am curious about my sound quality, I think wired headphone's sound are much better than wireless headphones.
  8. #8
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,670
    Points
    46,805
    Level
    52
    Quote Originally Posted by rajput9571 View Post
    I think you're right.
    With wireless there is the greater chance of hiss and static and interference. More adjustments to make for satisfactory sound.
    An amplifier powered by 2.5V (two AAA batteries).
    It becomes a question whether the freedom from wires is more important.
    I never had wireless headphones until these, because they were bargain priced, and because my good-quality wired ones have been acting up. I'd rather have a better set.
    Here's some that got good reviews:
    http://www.consumersearch.com/wireless-headphones
  9. #9
    Banned
    Points: 1,817, Level: 9
    Join Date
    May 2012
    New Delhi, India
    Posts
    341
    Points
    1,817
    Level
    9
    Dick
    Wireless headsets for TV usually use infra-red. This is because its easier/ cheaper/ better to use IR since its a TV !! And you are going to be in the same room facing the TV anyway..... yes ?
    However there ARE lots of wireless headphones which use radio. They work on FM, usually just below the 'normal' FM band frequency. FM is typically free from hiss/ static by nature, so if you have one of these and are still getting hiss/ static, then it's probably because you are either far away & on the threshold of the signal (hiss), or there's a loose connection someplace in the chain (static), OR your receive frequency is not matching the Tx frequency very well (hiss and static)
    The cheaper versions do not have a precision frequency control, and skimp a bit on the circuitry, so you might need to just upgrade to a better model for better sound quality.
    Of course the eventual sound quality ALSO depends on the actual headset speakers & construction. Good bass requires a more "capable" power source.... make sure your batteries are good ! Adding a largish cap across the battery has been known to help sometimes.
    I just noticed .. some of these rf headphones work on very high frequencies ... like 900Mhz. Well, at that frequency of COURSE you will have attenuation due to building structures (like the wall in your house), and be prone to interference from cordless & similar other devices !! My suggestion - go for a headphone which gives you the Wireless feature AND has an FM radio built in. But a slightly higher quality model than rock-bottom-price. It'll work fine.
    cheers!
  10. #10
    Newbie level 1
    Points: 42, Level: 1
    Join Date
    Sep 2012
    Posts
    Points
    42
    Level
    Has anyone considered wireless speakers as well? They use bluetooth technology and if you would rather broadcast what your listening to, rather than listen privately with headphones, they are awesome. If you're worried about price you can consider searching online deals sites. Not sure if anyone uses electronics deals sites, but you can save on accessories, if you want to get both wireless headphones, regular headphones and speakers until sold out. The wireless speakers are obviously better used with a phone or music player with wifi, but there are also other alternatives.
    Ice Monkey
    SIGNATURE LINKS ARE NOT ALLOWED
    •   Alt25th September 2012, 18:43
      advertising
  11. #11
    Full Member level 5
    Points: 2,533, Level: 11
    Achievements:
    7 years registered
    Join Date
    May 2009
    Mumbai, India
    Posts
    252
    Points
    2,533
    Level
    11
    Here's my take; I need wireless earphones on TV, and I really dont miss it not being stereo. I just expect a decent sound reception.
    Problem with dedicated units is that they need a proprietary receiver to be matched with a transmitter. The batteries on the receiver often die before the program you're watching gets over. And so on..
    What I did was make a simple FM transmitter (dozens of circuits on the web), and now I can use my cell phone (or any device with an FM receiver, like an MP3 player) as a wireless headphone. And trust me, if the FM radio is all that is running on your device (mine is an Android) the battery drain is negligible.
    Regards,
    Anand Dhuru
  12. #12
    Member level 2
    Achievements:
    7 years registered
    thudpucker's Avatar
    Join Date
    Feb 2007
    North Alabama
    Posts
    50
    Points
    1,636
    Level
    9
    You guys are a boon to an old idiot.
    I'd like the speakers idea pretty good.
    Two speakers in a box. I could sit it on the back of my easy chair or above my head as I lay on the couch. (draining a blood clot)
    I never liked head phones for fear of losing my hearing.
    I like the idea of the speakers responding to a home made FM transmitter.
    Great idea, many thanks.
  13. #13
    Join Date
    Aug 2012
    Posts
    15
    Points
    115
    Level
    Quote Originally Posted by BradtheRad View Post
    Thanks for sharing these valuable reviews, I know that Sennheiser is world class company for headphones so wireless headphones will be a good choice, thanks buddy.
  14. #14
    Newbie level 1
    Points: 41, Level: 1
    Join Date
    Sep 2012
    USA
    Posts
    Points
    41
    Level
    The Logitech Wireless Headphones for PC sound great, but some users may balk at their relatively short range and the lack of an integrated
    appliance test tag
    TestCorp provides ELECTRICAL TEST TAGGING, EMERGENCY EXIT LIGHT TESTING and FIRE EXTINGUISHER TESTING for South Australian businesses
